the pipe master
Trade: plumbing, solar
Down Sizing HID Lighting Bulbs
Can you replace a 1000W high pressure sodium bulb in with a 400W or lower bulb using the same ballast? I know you couldn't install a higher wattage bulb in a lower wattage ballast, but can you undersize the bulb and if so, is there any downsides?
Many thanks sparkys.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
Re: Down Sizing HID Lighting Bulbs
No. The ballast needs to match the lamp. In some cases, a mismatched ballast/lamp combination will appear to work, but the lamp and/or the ballast will have a sorely reduced life. I very much suspect that if you put a 400W lamp in a socket connected to a 1000W ballast that it'll just go "pop" and you wasted 20 bucks. If you want less light, change the ballast to match the lamp or install a new fixture. Sometimes a new fixture is cheaper.
the pipe master
cool. I was just curious.
| Energy Efficient lighting? Lighting specialists? | CNC | Electrical | 14 | 06-29-2008 02:16 PM |
| Residential General Lighting Circuits | toastermaker | Electrical | 11 | 02-26-2006 01:04 AM |
