Door Bell Diagram
Old 11-01-2007, 09:50 PM   #1
zbwmy's Avatar
Door Bell Diagram
I'm embarrased I can't do this. I took my bell down over a year ago, today I tried to wire up a new one and cannot get it to work. I labeled the wires, so how hard could it be?
Rear Door = 1 two conducter wire (red/white)
Front Door = 2 two conductor wires (red/white) twisted together by color
Transformer = 1 two conductor wire (red/white)
Bell Location = 3 two conductor wires (red/white)
I assumed a wire from each bell, and one from the transformer. But why is there two wires at front door?
Bell = labeled front trans rear
zbwmy is offline
Old 11-01-2007, 10:52 PM   #2
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Door Bell Diagram
Don't know what your situation is, but you need a continuity tester and ring out all the wires. Also a voltage tester to make sure your transformer is good.
Anyhow, here's a diagram;
Sparky Joe is offline
Old 11-01-2007, 10:56 PM   #3
Fentoozler
Celtic's Avatar
Don't be.
I took my DB down about 3 years ago.....it went back up just a few months ago ....but just the front works, the side pushbutton isn't even connected.
Celtic is offline
Old 11-01-2007, 11:18 PM   #4
mickeyco's Avatar
Trade: Squirrel Handler
I didn't reload to see Joe already drew it so I'll post mine as well.
mickeyco is offline
Old 11-04-2007, 06:19 PM   #5
MSSI's Avatar
Trade: Electrician
DONT forget the diode........(for electronic chimes)
MSSI is offline
Old 11-04-2007, 06:22 PM   #6
MSSI's Avatar
Trade: Electrician
Diode usually goes on the front button paralel
MSSI is offline
Old 11-04-2007, 11:51 PM   #7
L. B. Condulet's Avatar
Trade: Super Electrician
Talking
I have never installed a rear door bell push button. Here in Los Angeles everybody has enclosed back yards and it would be real creepy if someone was in your backyard, and wanted to speak with you...
L. B. Condulet is offline
Old 11-05-2007, 01:09 PM   #8
zbwmy's Avatar
I dont remember pigtailing any wires before. All whites on the bell terminals, and all reds wire nutted together at bell?
zbwmy is offline
Old 11-05-2007, 02:28 PM   #9
Lightbulb
That won't work for me since I wire all doorbells in Cat 5e. I do that in case someday down the road they want to upgrade to a high speed doorbell. It's all about putting the customer first.
Old 11-05-2007, 03:30 PM   #10
mickeyco's Avatar
You may need to call in a door bell specialist, I recommend Señor Ding-Dong from Señor Ding-Dong's Doorbell Fiesta.
mickeyco is offline
Old 11-05-2007, 07:08 PM   #11
72chevy4x4's Avatar
are the two sets of wires at the front switch wired together (in parallel) or is the second wire set passing through? If it's 'passing through', it's the rear door bell switch and would be wired accordingly.
72chevy4x4 is offline
Old 11-06-2007, 10:48 AM   #12
zbwmy's Avatar
The two sets of front door bell wires are twisted together by color, and terminated at the switch.
zbwmy is offline
Old 11-06-2007, 12:21 PM   #13
220/221's Avatar
Trade: electrician Phoenix AZ
THAT is the $64K question.
Perhaps when the house was built, the front door wire was long, and folded over and stuck so they just hooked up "both" wires ...which were really the same wire.
It's a stretch but do you have anything better?
Sounds right. You probably just don't have the whites in the proper order.. If you don't have a meter, you can find the transformer wire by ringing the chime...assuming the transformer works. You may also be able to detect a small spark when you touch the transformer leads together BRIEFLY. Just a little touch.
220/221 is offline
Old 11-06-2007, 04:34 PM   #14
mickeyco's Avatar
What type of contractor are you? All of your posts seem to indicate you are a homeowner doing work on your own house, I may be wrong.
On the door bell thing there could be any number of explanations as to why there is an extra set of wire. Could have been 2 doorbells on the house at one time (maybe it was split up as rentals). Could be one set of wires was damaged with a nail or screw, they pulled a new set and left the old ones there. Could be the transformer is on the other side of the front door switch and follows the route back to the bell unit with the switch wires (ie. the extra set is the transformer wires). It doesn't really matter, test the wires, then use the diagram, if the new doorbell came with a diode install it, done.
mickeyco is offline
Old 11-06-2007, 04:49 PM   #15
Ding, ding, ding, ding!
Mickey wins
Every thread he's started is about his house.
Every one is DIY question, except when he's price shopping.
neolitic is offline
Old 11-08-2007, 06:04 PM   #16
zbwmy's Avatar
Mickey wins
I just like coming to the experts for advice. I paid contractors over $15000 this year to do work around the house. I support the trades, just want to fix the door bell
zbwmy is offline
Old 11-08-2007, 06:42 PM   #17
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
ProWallGuy is offline
Boiler Diagram LWF HVAC 21 11-02-2010 07:26 PM
Electrical Riser Diagram nehal101083 Electrical 9 02-09-2007 06:30 PM
inground pool wiring diagram sparklito Electrical 3 01-13-2007 01:45 PM
Washer wiring diagram grabo1530 Electrical 3 09-02-2005 12:13 AM
Riser Diagram? ZMAN Electrical 2 06-01-2005 07:33 PM
