Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Closed Thread
Old 08-31-2009, 03:51 AM   #1
Trade: Plumber
does the garage really need the GFI?
I really hate doing electrical because I don't always know the answer. So hopefully somebody can help me on this one.
One of my customers asked me to remove the GFI outlet from the garage because it falses (turns off) to often. He stated that he hired an electrician last year to repair the GFI and the electrician changed it with a new one. However, the GFI continues to false. He stated the GFI falses about once a week when he uses his power tools in the garage. So he is so frustrated with the GFI that he wants it totally removed. (Currently he is running an extension cord from the inside of the house to avoid the GFI outlet in the garage.)
My question is why is there a GFI in the garage anyway? I understand there is a GFI in the restroom because drop hair dryers in the water which can electrocute. However, the garage is a mystery to me.
I appreciate it if you are not going to help me, don't even bother posting on my thread. Now if you can help me, then please post. My customer is waiting for my response. I told him that I would remove the GFI outlet after I got some consultation from my electrician buddy. (Which is you guys of coarse.) If nobody can answer me, the I assume that GFI is not necessary in the garage.
thanks.....
handyman99 is offline
Old 08-31-2009, 04:43 AM   #2
GFI in Garage
Handyman99 - I want to try and help you so we can both be offline when the electricians wake up and see that plumbers and generals are messing with their GFI's.
Your last point first: I wouldn't assume that just because no-one at CT says otherwise that it's OK to take out a GFI!
Then your first point - why have a GFI in a garage? Not a bad question, and I suspect you"re looking for something more than "required by code".
Bare concrete = ground. Tile on a slab and metal pumbing fixtures (like in a wet kitchen, bath and laundry) are even more potentially dangerous, but same principle in a garage.
Won"t be surpised one day to see GFI required everywhere .
So far, the sparkies are eyeing me cautiously; now I'm getting into their territory, and that can be more dangerous than dropping my hairdryer in the tub.
Before you get yourself into real trouble,
1. try using a 20amp GFI, if the wiring/breaker are 20amp.
2. check if there's a GFI "up-stream" on this same circuit.
3. make sure it isn't a split circuit with a common neutral.
4. ask your electrician to stop messing with your pipes.
It's been fun, but I gotta get out of here.
bradgunn is offline
The Following User Says Thank You to bradgunn For This Useful Post:
handyman99 (08-31-2009)
Old 08-31-2009, 04:56 AM   #3
thanks.....
Actually, you're scaring me me. Asking questions is OK. But I think you're in a little over your head. Please get a licensed electrician. Now.
bradgunn is offline
Old 08-31-2009, 05:19 AM   #4
Celtic's #1 Fan
Trade: electrical
hey brad,
please be advised that you are pissing directly into the wind....
mahlere is offline
Old 08-31-2009, 05:35 AM   #5
Yeah, I just found his other post. I'm feeling pretty stupid right now. Those guys are going to find this thread, and come tomorrow they"ll be on me. Last time I try to help someone late at night.
BTW, Handyman, you gotta admit, I was nice to you, right?
bradgunn is offline
Old 08-31-2009, 05:59 AM   #6
Trade: Electrical
I'm thinking PGD or Bob is back
TxElectrician is offline
Old 08-31-2009, 06:31 AM   #7
Super Genius
Trade: No trades, no CCs. Cash or check, please.
Shoot, I pee in my garage, that makes it a bathroom so it does need a gfi. If I'm working at your house you darn well better have a gfi in the garage because sooner or latter I'll have to pee. In your garage.
davitk is offline
Old 08-31-2009, 06:34 AM   #8
Pompass Ass
thanks.....
Do yourself and your client a favor and tell them to hire someone who knows what they are doing, in this case a Licensed Electrician.
You obviously have no business touching electrical because you have no clue what you are doing and when you do electrical work for a client, not only should you know what you are doing, but you should be licensed as well.
bwalley is offline
Old 08-31-2009, 06:44 AM   #9
Burritos
Trade: Lectrical
Sigh...
Since the GFCI has been replaced already, it is probably one of the HO tools that has gone bad. It seems like he trips the GFCI with regular interval, so whatever he is using when the outlet pops needs to be replaced.
bamawildcat is offline
The Following 2 Users Say Thank You to bamawildcat For This Useful Post:
handyman99 (08-31-2009), SewerRatz (08-31-2009)
Old 08-31-2009, 07:43 AM   #10
Thom
thom's Avatar
handyman, you seem to do a lot of electrical work. Why not just buy yourself a code book and the related hand book? Oftentimes what seem like simple questions to you are not so simple. There are a variety of things that can affect the answer that you have not considered.
Doing this without a clear understanding of all the parts really is dangerous. It may take time, even several years, before some of the problems manifest themselves as fires or dead customers. It really is better to learn what you are doing here.
In this case, the simple answer is in the code book. The guys who write the code books consider a whole lot of stuff when writing it. They don't tell us all that stuff, just the rules. So, we do it because code requires it.
Always remember, the statute of limitations on code violations starts running when the building owner becomes aware of the violation. What that really means is you are legally responsible for all the work you've done until your estate has been settled.
thom is offline
The Following User Says Thank You to thom For This Useful Post:
Old 08-31-2009, 08:00 AM   #11
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
Age is just a number but mine is unlisted.
480sparky is offline
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
EBFD6 (08-31-2009), Magnettica (08-31-2009)
Old 08-31-2009, 08:01 AM   #12
joasis's Avatar
I will say this again, but do you have insurance? How will you feel if one of your "shortcuts" gets someone hurt, or even killed? Electrical shocks have been fatal.....and if their home burns down, do you have enough insurance to cover the bill? How about a fatal fire?
Why not stick to handyman stuff and leave electrical work for electricians?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is offline
Old 08-31-2009, 08:18 AM   #13
God Bless America
Magnettica's Avatar
Trade: Electrician
I'm finishing my basement. Do I really need a vapor barrier? That's a big waste of money if you ask me so screw it I'm not putting one in.
I hate the look of suspended ceilings too so up goes the sheetrock.
Plumbing shutoff valves? Waste of time. All they do is open up the possibility of someone shutting them off and then I'll have no running water.
Vapor barriers, drop ceilings, and shutoff valves.... who needs them?
Classic Electric LLC
Repairs, Renovations, Rehabilitation
Magnettica is online now
Old 08-31-2009, 08:20 AM   #14
#1 stunner
Trade: Design/Build
Send a message via AIM to Static Design
Yes, why? Because the NEC said so.
Will do autocad/ 3d work for food.
Static Design is offline
Old 08-31-2009, 08:24 AM   #15
480sparky's Avatar
H99's a full-blown hack. He doesn't give a shît about codes.
Old 08-31-2009, 09:29 AM   #16
Pompass Ass
I don't think his hack insurance will cover that, if I work outside of the scope of my licenses and what I have listed on my insurance application, they can deny coverage.
When this hacks customer's kid dies because they plugged in an extension cord into a formerly protected GFCI outlet and drop it in the kiddy pool and die, how is insurance going to compensate the parents who lost their kid?
What is the handyhackman going to do about it?
bwalley is offline
Old 08-31-2009, 09:37 AM   #17
480sparky's Avatar
The painfully obvious is not so obvious to Handyman99.
The reason the GFI trips is because it is doing it's job protecting people.
Now you want to remove that protection. Instead of finding the problem, you want to cover it up. For money.
The Following User Says Thank You to 480sparky For This Useful Post:
bwalley (08-31-2009)
Old 08-31-2009, 10:10 AM   #18
Sparky, I would think your neck is
pretty sore by now, cause someone
has been jerking your chain.
neolitic is online now
Old 08-31-2009, 10:24 AM   #19
Trade: Home Remodeling
Talking
Becareful... Red Alert = High Blood Pressure Signal.
Ignore (handymen) = Best policy!!
SelfContract is offline
Old 08-31-2009, 11:23 AM   #20
slowforthecones's Avatar
Trade: General Contractor & Fire Protection
Good idea.. this particular "handyman99" is a real loser.... we shall vote to regulate him to the DIY only.
slowforthecones is offline
Closed Thread
Pole Barn Garage mrmike Carpentry 26 10-28-2009 07:29 PM
Price for Fill / Garage Slab Prep -- Opinions? slr2974 Excavation & Site Work 9 06-17-2009 09:22 AM
Heating detached garage - gas supply line question jarvo807 HVAC 11 06-14-2009 11:10 AM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 10:00 AM
