Trade: electrician
Do You Need AFCI On Service Upgrade In NY?
I have to upgrade a 100a service to 200a. Do I need to protect the bedroom circuits with AFCI's? I am from NY state.
Master Electrician
Trade: Electrician
Re: Do You Need AFCI On Service Upgrade In NY?
I would say yes. Since you are going with a "new" service, it will probably be required, but as always, check with the "Authority having jurisdiction".
It may also be required to do more than the bedrooms, as one inspector told me, "Any livable space required AFCI protection" |
Trade: Electrical and mechanical contractor
I always upgrade to AFCI's when replacing a panel or upgrading a service. As far as I understand it, any bedroom outlet, smokes included, must be AFCI protected. I would do this even if the inspector did not require it because they're still using old books.
DGFVT
Trade: Electrical
Look at these posts it will answer you question.
http://www.contractortalk.com/showth...ervice+upgrade |
Electrical Contractor
Trade: Electrical
NO, you do not need to install AFCIs for a service upgrade. The above posts are OPINION only, and not based on NYSRBC facts.
The service has nothing to do with branch circuits, and AFCIs are only required for NEW branch circuits. Some areas do have a rule to install them for upgrades but NY is NOT one of them. krthomp33, "It may also be required to do more than the bedrooms, as one inspector told me, "Any livable space required AFCI protection" Is this an actual code in your area or does your inspector like to make up his own?
Electrician
Trade: Electrician
Doesn't the 2005 NEC require that any panel or service uprade needs to also have AFCI's installed on all bedroom circuits now. A smoke detector is not an outlet, it is directly wired.
#7 | ||
Trade: Electrical
Re: Do You Need AFCI On Service Upgrade In NY?Quote:
Local codes may differ. Quote:
Trade: ELECTRICAL
Tell 'em Petey!
DGFVT
Trade: Electrical
I have a question to all. In your area of the country is there any AHJ that requires a full or partial house rewire if the main service is changed? Common sense would dictate that you would try to talk the customer into having it done with the service change. I have fallowed up behind a lot of just service change overs where somebody is just out for a quick buck and doesn't want to deal with the rest of the house.
#10 | |
#11 | |
#12 | |
Master Electrician
Trade: Electrician
The argument that I got was that the living room can be used as a bedroom, all they needed was a fold out couch, and it becomes a bedroom. I argued for about 20 minutes, but let the inspector have their way. Better to maintain a good relationship, than to piss of the inspector!! |
#13 | |
Trade: Electrical
A service upgrade is one of the bread and butter jobs in our trade. Of course we try to get more work out of doing one, but to suggest a whole house re-wire because of a service change is most times ludicrous. I guess most houses you do service changes on are POS fix-er-uppers. Most of the ones I do are perfectly fine with electrical systems in good shape, they just need a new service. Of course many need an extra circuit in the kitchen or bathroom, etc, which we would all try to have the customer do, but this does not even come close to justifying a complete re-wire. Then there are the complete gut reno's with a service and re-wire. Just MHO.
#14 | ||
Trade: Electrical
I guess I am lucky to have inspectors with common sense and who are reasonable. It is distressing to hear about so many who are on power trips and make up their own personal requirements.
Speedy you are right BUT (i'm opening a can of worms)
when you do an electrical upgrade a permit is required N.Y.S. Code |
Trade: Electrical
Actually an inspection is required, a permit is not...in most areas.
I have heard of some small municipalities that do require a building permit to do a service change.
Electrician
Trade: Electrician
The box a smoke is connected to is most definitely an outlet. Read the definition of "outlet" in Art.100.[/QUOTE]
....Then I guess EVERY inspector in EVERY munincipality in the Chicago land area has to reread article 100. There was one inspector that was going to require us to put the smokes/cos on an arc fault, but rethought it. And this town is STRICT they require sprinkler systems in all new housing. We have never been required, or even asked, to put smokes on an arc fault. |
#18 |
Trade: Electrical
NEC 100
Outlet. A point on the wiring system at which current is taken to supply utilization equipment. An example is a lighting outlet or a receptacle outlet. A smoke is utilization equipment, is it not? I'm not saying your inspectors are right or wrong in requiring smokes on AFCI. In fact I think it is ludicrous to have smokes on AFCIs. I am saying they are wrong in thier interpretation if they are saying a box a smoke is attached to, and fed from, is not an outlet.
#19 |
Electrician
Trade: Electrician
I agree with you speedy, it is dumb. The main intent or AFCI's and why the local enfocement officers have been pushing for them, results from the number of fires in bedrooms that were caused by improper use of extension cords, or just "equipment" with a cord. Too often cords get abused and they fray, or the ends go bad.
#20 |
Sprinkler systems in all new homes?! Good lord, what's next, the government forcing their citizens to buy health insurance? Oh yeah, that's already starting.
I would think if any area mandated smokes be on arc faults it would be Chicago, that's surprising.
| Cost to upgrade service | Woodcrafter74 | Electrical | 46 | 01-30-2008 08:30 AM |
| Service upgrade | JamesNLA | Electrical Picture Post | 23 | 04-22-2007 02:01 AM |
| Can anyone make any sense out of this? | Teetorbilt | Technology | 24 | 04-16-2007 12:21 PM |
| 400-A Service upgrade pricing | BIGRED | Electrical | 69 | 02-03-2007 11:39 PM |
| Service upgrade question | ATS | Electrical | 17 | 09-05-2006 09:48 PM |
