#1 | |
On Discouraging DIY Electrical Work...
I borrowed this from another tradesman, and it sums up my feelings pretty well on DIY electrical work:
Re: On Discouraging DIY Electrical Work...
Though I agree with you (sometimes with great pain
P.S. Awesome on the Avatar!!
http://www.tr-built.com |
#3 | |
Re: On Discouraging DIY Electrical Work...Quote:
Tom, Tom, Tom. You disappoint me. Not using an anti-syphon ballcock in the tank can cause toilet tank water to mix with the potable water. Improper waste venting WILL NOT cause toilet bowl water to mix with the potable water. Ever. Period. I might be younger than you, but I ain't nobody's fool. Perhaps I should tell you that I invented indoor plumbing when I lived in Greece in my youth. I really wasn't interested in comments on plumbing here anyhow. I just wanted to pass along that just because an electrical installation functions never means that it was either safe or code compliant. |
Durn, - - not tryin' to talk plumbin', - - but will this be putting a 'damper' on my hero status??
#5 | |
#6 | ||
Trade: underground
I can't however disagree with you if your main premise is that most pros are eminently more qualified to do the work than most DIY'ers. There it is - you got me to hang out my laundry for the world to see Last edited by PipeGuy; 12-02-2005 at 10:07 PM. |
Trade: underground
I just picked up on the Avatar(s). ROFLMAO! You're quite the
You've got me thinking.........Last edited by PipeGuy; 12-02-2005 at 10:23 PM. |
Even the pro's aren't perfect. I went into a new development this week, plugged into a garage receptacle to operate a circular saw and it ran when I checked it but not when I went to use it. Plugged in my quickie checker and it indicated reversed polarity. Pulled the receptacle (back stabbed) and the line side slipped out of the neutral hole.
#9 | |
#10 | ||
One assumes that a new home has been done by a 'pro', I would hope. The home passed inspection and was granted a CO. A failure and hazard due to the fault of many. CHEAPOS.
Chief Toilet Mover
Trade: Bathroom Remodeling
I'll never forget when the electrician I hired F-up my simple electrical hook up to my hot tub. Since we were building a deck around it the tub never got turned on for over a month and only then did we discover we almost blew the electronics of the panel thanks to the bone head electrician.
As strange fate would have it the very day we discovered this, while the hot tub installers were there fixing the electricians mistake the electrician called me out of nowhere to ask me if I had any more work for him!!!! What were the odds? million to 1? I explained the problem, he said he would arrange a time to come fix it and of course he was never heard from again. He's licensed by the state of Colorado, nice huh? Md, I certainly understand your point of your post but the word "never" have to worry about it might be viable if you were the guy I hired, but "never" is a bit too general for the rest of the electricians in Colorado. |
#13 | |
Repair/Remodeling Tech.
Trade: Repair and Remodeling Services
Not trying to be smart or start anything, I'm all ears...er uhh...eyes, but I can't think of a single safe deficiency in electrical work.
Jim P. |
jp, you are right on all counts. Unfortunately, today the $$ speak and we are stuck with crap like Romex scattered all over the place to save more of aforementioned.
If Romex is an unsafe deficiency, then the pros are just as unsafe as DIY'ers (around here anyway). Every new home has Romex and is wired by a pro.
Jim P. |
Custom Builder
The electrician is the last fella ya want with a buzzzzz.
Bob
Bob |
#17 | |
How about the receptacle layout along a kitchen counter doesn't match the counter layout symmetrically. A deficiency, but not a hazard. How about the light box next to the front door mounted too close to the brickmold so that the intended fixture can't be mounted? A deficiency, but not a hazard. How about all the bedrooms on one circuit, and now the homeowner's SuperServer 9000 computer in the middle bedroom pops the breaker? A deficiency, but not a hazard. How about a back door chime button that was never mounted? A deficiecy, but not a hazard. How about all the devices done in regular ivory, when the occupant wanted white decora? A deficiency, but not a hazard. The list goes on and on... In Mike's case with the hot tub, there are screwballs in every lot of tradesmen. Your likelihood of running into one in the population of licenced EC's is much less than your likelihood of finding one in the population of DIY's. You can still have a licensed roofer put on a roof that leaks, but your chances are much less than if you had Joe Blow the Handyman put on your roof. The fact that this electrician had to cold call, trawling for work, speaks volumes. Last edited by mdshunk; 12-03-2005 at 11:38 AM. |
#18 | |
Chief Toilet Mover
#19 |
listen twice talk once!
Trade: electrician
Even putting a wire on a screw can be messed up. And I ve seen it burn receptical to a crisp. And one was next to a two year olds bed recently. She told me she listened to it a night. All because they had there builder/remodeler install new decora plugs. Over half of my service call for stuff not working are all because of not so handy men. I think the situation is so bad Iam keeping stats, in a couple of years I ll tell you what up!
#20 | |
| What the worst electrical safety issue you have seen? | SuperiorBuilt | Electrical | 63 | 01-02-2010 12:28 AM |
| Here I am again, doing some electrical work | mickeyco | Electrical Picture Post | 1 | 05-18-2007 01:59 PM |
| Utility Service Work | denick | Excavation & Site Work | 6 | 01-03-2007 09:31 PM |
