Trade: Electrician
Disconnect For Lighting
Does anyone make a fused disconnecting plug setup for the florescent fixture "disconnect" requirement?
Fentoozler
Re: Disconnect For Lighting
Is the requirement:
A) That there is a disco B) That there is a FUSED disco Chose wisely, young grasshopper...
Trade: Electrician
Spec says "all light fixtures are to be fused"
NEC calls for the Disconnect, Correct? |
Service & Repairs
Trade: Electrician
Check NEC 410 for the disconnect requirement. I think they want that quick interlocking snap connector (WAGO) that comes pre-installed from most manufacturers.
Service & Repairs
Trade: Electrician
410.73 (g)
Fentoozler
NEC calls for a disco [410.130(G)(1) ~ '08; 410.73(G) ~ '05]
I would question "All light fixtures are to be fused".
Why? He said that's what the spec says. They can make a spec that all fixtures are to be purple polka dotted. If they do, then you need purple polka dotted fixtures. I'd just add an inline fuseholder to the fixture and be done with it. Fluorescent fixtures are going to come with the disconnect plug in they from the factory nowadays anyhow, so you don't even have to puzzle on whether the inline fuseholder will qualify as a disconnect. You'll have both.
Fentoozler
Service & Repairs
Trade: Electrician
Did a bunch of lights last year with the inline fuses in them but they were HO lights with magnetic ballasts from the 1950's!
Trade: Electrician
160 pages of electrical specs and 3 pages of E prints..I just need to note that We dont cover fuse changes as a warranty issue. Thanks for your replies. I guess Ill go the inline fuse route.
Electrician
Trade: Electrical Contractor
I had a spec like this some time back. I used in line fuses. I later found out that the engineer figured if a fixture shorted, it would blow the individual fuse rather than trip the branch circuit breaker, plunging the office people into darkness.
This was before the disco rule.
John |
#12 | |
Re: Disconnect For LightingQuote:
http://www.newark.com/jsp/search/bro...se+holder&Ntx= |
#13 | |
Fentoozler
Electrician
No emergency lights in the individual offices, just in the hallways for egress. And the idea was to keep productive even though one fixture was out. I wonder if it ever happened.
John Last edited by jrclen; 12-06-2008 at 04:47 PM. |
#15 | |
![]() Trade: student again
Those are for cars. With a maximum voltage rating of 32v, it wouldn't be NEC compliant. I don't understand the purpose of inline fuse for light fixtures. Each electronic ballast is internally fused with a standard fuse. |
#16 | |
Trade: Electrical
How do you change it?
Eh, that was just a for instance. You know they make 125V rated inline fuseholders. That was a quick link to get him started.
#18 |
Trade: Electrician
I cant think of any real good reasons to fuse a 4 ft fixture thats 8ft off the ground. I can understand it for HID Thats had to get to and expensive to repair.. This thing went out for rebid because they are over budgit.
DUH No s t.....You paid someone 40K to come up with 662 pages of specs for a 1000sqft consession stand and 2 bathrooms.. A $42,000 inverter.. Incase the power goes out, we need to keep the weenies warm. All #10 home runs for 20A circuits. Etc...Let them enginers have a little slack and your gonna wind up building a Space Shuttle instead of a pop stand. |
#19 | |
Fentoozler
Re: Disconnect For Lighting...and there's the answer: Quote:
It's a widely known fact that I have psychic abilities
| Disconnect at meter can | pudge565 | NEC Discussion | 28 | 11-26-2008 07:09 PM |
| Location of disconnect? | jimb317 | Electrical | 16 | 09-19-2008 05:01 PM |
| Fart Fan means of disconnect | JamesNLA | Electrical | 11 | 05-06-2008 12:19 AM |
| Is a main disconnect code requierment? | pitterpat | Electrical | 25 | 11-11-2007 10:58 AM |
| Distance for Disconnect? | sandyman720 | Electrical | 4 | 09-18-2007 09:06 PM |
