Dimming Lights In House
Old 01-02-2004, 03:41 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
I'm having a problem in my home with lights dimming. I have checked the ground connection to the cold water system, main panel for loose connections, meter socket for loose connections. I was unable to check the ground connection at the rod outside because its buried too deep. I performed a test using a 1250 watt hair dryer to put a load on a branch circuit that was on phase A. The voltage without the hair dryer on was 121.3, when I turned the hair dryer on, the voltage dropped to 119.8. I performed the same test of phase B and the voltage was 122.6 with the hair dryer off and 121.4 when the hair dryer was turned on. I also checked the voltage across A and B phase, it was 243.9, then I turned the hair dryer on and the voltage dropped to 242.8. I called the power company, and they told me if they can't find the problem, I would be billed for the crew's time. Any input from you on this matter would be greatly appreciated.
The testing was performed with a fluke 87 true rms multimeter.
Old 01-02-2004, 03:44 PM   #2
Administrator
Nathan's Avatar
Trade: Admin
Re: Dimming Lights In House
I'll let an electrician answer.
But, please sign your posts so we know who you are...
Better yet, Register!
Thanks
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline
Old 01-06-2004, 11:57 PM   #3
Unregistered
Guest
Posts: n/a
Question
do the lights dim only when major appliances come on??? if so it sounds like a voltage problem not with the power co. but the wire size (awg) feeding the major appliances.ex--a/c, heat, dry,H2O heater maby. question are the appliances far from the power sorce?? make sure your service conductors are the proper size (2/0--3/0--4/0--500kcmil etc............
Old 02-16-2004, 04:51 PM   #4
Unregistered
Guest
Posts: n/a
Angry
The lights will dim when the well pump turns on ,clothes dryer.I can plug a hand held hair dryer into any receptical in the house and the lights will dim.
Old 02-16-2004, 04:55 PM   #5
Unregistered
Guest
Posts: n/a
Iforgot to mention that the service is 200amps and the feeder size is 4/0 aluminum.All connections are tight .
Did you see Flip this house - Cat House? SuperiorBuilt Off Topic (Non Trade) 18 01-24-2011 05:17 PM
House moving Toolwh@#e Excavation & Site Work 10 10-21-2007 11:23 PM
`Flip This House' star accused of fraud AmeliaP General Discussion 28 06-03-2007 10:21 PM
Funding for first spec house? ruskent Business 28 01-17-2006 08:10 PM
prob with dimming lights greenley Electrical 2 01-06-2006 10:56 AM
