tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Different Circuits Sharing A Neutral
Old 01-19-2009, 07:45 PM   #1
paintr56's Avatar
Trade: paint contractor since 1974
Rewards Points: 250
Is it common practice when using conduit to have neutrals from different circuits tied together in an electrical ceiling light box instead of running to the breaker box as separate runs?
Jim
paintr56 is offline
Old 01-19-2009, 08:09 PM   #2
SoCal electrician
Hidyusbeast's Avatar
Trade: electrician
Rewards Points: 25
Re: Different Circuits Sharing A Neutral
No, but are the circuits on separate phases?
Hidyusbeast is offline
Old 01-19-2009, 08:10 PM   #3
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
Sure...saves a ton copper [which = $$$]...but only if you know what you are doing.
Celtic is offline
Old 01-19-2009, 08:52 PM   #4
paintr56's Avatar
Rewards Points: 250
Total of three circuits so two are on one phase the other is not. How bad is this? Any problems that would require having the house looked over more closely? The house was built in 04.
Jim
paintr56 is offline
Old 01-19-2009, 09:16 PM   #5
Handle It!
MALCO.New.York's Avatar
If you are asking this question, how do you know that there is a "Phase Bump" occurring?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 01-19-2009, 09:51 PM   #6
paintr56's Avatar
Rewards Points: 250
Originally Posted by MALCO.New.York View Post
If you are asking this question, how do you know that there a "Phase Bump" occurring?
Maybe I don't. It is my understanding that the two feeds coming into the box are at different phases, and that a 220 breaker would be coming off the two phases. The hot wires going through the conduit are fed from three breakers all in a row one above the other. Please correct me if I am wrong.
Jim
paintr56 is offline
Old 01-19-2009, 10:32 PM   #7
Handle It!
Jim
What is it that the Plumbers always say???????
Call your Electrician. He will know!!!!
Old 01-20-2009, 06:35 AM   #8
Master Electrician
Bubbles's Avatar
Trade: Electrical
Rewards Points: 250
Put an Arc Fault Breaker on that cir. and see what happens
Bubbles is offline
Old 01-20-2009, 07:04 AM   #9
mrmike's Avatar
Trade: Electrical & Carpentry
Jim
What are you guys talking about????? Seperate phases???? A 3 phase house? Do you Know???? Hire a real electrician instead of trying to figure it out yourself or by such an errant answer here.................
mrmike is offline
Old 01-20-2009, 07:20 AM   #10
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Jim
Yes it is common, legal, acceptable and safe for more than 1 circuit to share a neutral, look it up in NEC.
Dedicated circuits will have their own neutral and ground.
If you are having problems and don't understand electricity call a licensed electrical contractor.
bwalley is offline
Old 01-20-2009, 09:33 AM   #11
listen twice talk once!
Bkessler's Avatar
Trade: electrician
Jim
Where are you located Jim?
Bkessler is offline
Old 01-20-2009, 04:40 PM   #12
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
I was thinking the same thing. Triple phase in a house? I have seen it before (Short Hills, NJ), but it is very rare.
Magnettica is offline
Old 01-20-2009, 04:45 PM   #13
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Jim
Think of it this way.... if a normal single-family dwelling has a 3-wire service (two ungrounded, one grounded), then a 3-wire circuit within the dwelling is suffice. The same rules apply for a 4-wire Wye (208/ 120 VAC), where a single neutral is used as a common point for each of the phase conductors. There are others used in the industry but this should hopefully answer your question.
Old 01-20-2009, 05:19 PM   #14
paintr56's Avatar
Rewards Points: 250
I think I may have offended some of you by asking a question. I am not having a problem. I found this while changing a light fixture and I have never seen it before. I just asked if this was reason to call in an electrician or if it was normal.
Jim
paintr56 is offline
Old 01-20-2009, 05:29 PM   #15
Pompass Ass
bwalley's Avatar
Jim
I may have misunderstood you.
Are you having a problem with the circuit?
Or did you just see something you thought was odd?
bwalley is offline
Old 01-20-2009, 05:39 PM   #16
Fentoozler
Celtic's Avatar
It's a lot more common than one would think... Watchung, Weehawken, even Jersey City [think hi-rise condos...dual floor units w/private elevators]
Celtic is offline
Old 01-20-2009, 05:42 PM   #17
Fentoozler
Celtic's Avatar
Jim
What needs to be determined is:
- Do we have 1 - 2 - 3 or more circuits sharing the neutral?
- Is the service 1 or 3 ?
Simply because a box has several wires in it, that is not a clear indication of the number of circuits in the box.
Celtic is offline
Old 01-20-2009, 07:20 PM   #18
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Yes, if 3 circuits are sharing a single neutral on a 1 (single phase) service then that neutral would carry the sum of 2 of the ungrounded conductors and the difference of the other 2 pairs not on the same phase.
Getting all this Jim?
Old 01-21-2009, 12:02 AM   #19
paintr56's Avatar
Rewards Points: 250
We have 3 circuits coming off of two legs in a single phase system. The three breakers are locate one above the other.
I seem to have confused things when I mentioned two phases. I thought the two legs were 180 degrees out of phase. When Hidyusbeast asked if the circuits were on one phase or two I thought he was talking about the two legs.
Jim
paintr56 is offline
Old 01-21-2009, 12:18 AM   #20
paintr56's Avatar
Rewards Points: 250
I think I am getting about 80% of it. When you say not on the same phase am I correct in thinking you are talking about feeding off of separate legs?
From what I am reading about the nec shared neutrals are called common neutrals and code calls for them to be fed from separate legs to balance the load. Not sure if balance is the correct term. When sharing the same leg the capacity of the neutral could be exceeded.
Jim
paintr56 is offline
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 03:18 PM
shocked when touching bath faucet earl964 Electrical 28 09-16-2008 04:50 PM
Multiwire branch circuit code (sharing neutral) CNC Electrical 12 08-04-2008 11:58 AM
Sharing a neutral for a 3 wire dryer ShopDog Electrical 3 12-06-2006 05:05 PM
Using 12/3 to power Two Circuits robertc65 Electrical 18 02-15-2006 11:26 PM
