Trade: Electrician
Dedicated Tv / Flatscreen Circuits?
Dedicated Tv / flatscreen circuits?
Im adding some recepticles for a customer behind his new flat screen tvs, is it a common practice to dedicate these? its a brand new house, but its done, so its all remodel work, so i of course am fishing. So i know the circuits arent stingy as they would be on an older house, so if i have to juntion off existing plug circuits within the actual room the tv is in, i wont be concerened with the load. IM just curious because of the fact that its a high end tv if its a good idea to dedicate? and if so what the reasons are? Basically i have heard for equpiment like this its nice to isolate a ground? which i dont know could be a load of BS. just seeing if anyone has some technical insight with this stuff. do any of you use the recessed clock plugs for these types of tvs? for some more clearance? |
#2 | |
Old School Marine
Trade: Union Journeyman Electrician
Re: Dedicated Tv / Flatscreen Circuits?Quote:
I would do isolated ground to avoid electrical noise that may cause issues with hard drives etc. I always use the recess boxes that have the cable connections and recepticle adjacent to each other on opposing 45 deg angles, so it's all hiden behind the tv. |
Trade: electrician Phoenix AZ
It's always a good idea to dedicate but it's not generally necessary.
Trade: Low Voltage
If it's a large system that is going in, yes definately. 20A circuit just for the equipment, and a 15A circuit for the display is fine.
All the equipment goes through some power conditioners and battery backups, so the isolated ground may not be needed. |
Trade: Union Electrician
As stated earlier, some of larger screens will definately draw a lot op power. I once installed an 86" plasma that was around 1800 watts. Considering the investment that some of these TV's entail, it never a bad idea to put a TVSS receptacle on them.
I try to dedicate a circuit to the larger one's if the customer can fit it in the budget. Also, strongly consider using one of these new puppies for the receptacle set-up behind the TV. They're only about 20 bucks, from Arlington Industries:
![]() http://www.aifittings.com/whnew98.htm |
Trade: Low Voltage
Or put a piece of 2" vac pipe behind the display to the basement or where ever is best for the components. No point in locking yourself in to a cabling type when it will all change again in 5 years.
#8 | |
Old School Marine
#9 | |
#10 | |
Old School Marine
Never saw that little one, that would be great for refrig. outlets. I don't get into resi so unless we are doing a kitchen or bar in an office that is behind schedule I don't get into stuff like that. |
#11 | |
#12 | |
Old School Marine
Trade: Electrical
Isolated ground receptacles are a waste of time/money if you are using NM cable and plastic boxes ....
#14 | |
Trade: Electrician
I was just refering to isolating the gorund with a dedicated circuit. can someone ched some light on why in fact some electronics call for an isolated ground/ isolated ground recepticle? more for sensitive audio equipment and ground noise? what about video? Neat stuff guys. Just the regular clock hanger recepticles will do also, right? easy to find, but they do have those annoying hooks, that are an eye sore if not being used. Id like to stock up on a few of those box combinations, doubt my parts house has any. Any one mail order? |
Re: Dedicated Tv / Flatscreen Circuits? |
#16 | |
I believe NEC allows for the IGR's EGC to be terminated in a panelboard, but I could not confirm. Usually, an isolated ground bus is added, which is bonded to the building ground (at least in Chicago). |
| Seperate circuits grounds and neutrals | davidchomes | Electrical | 44 | 09-03-2007 10:57 PM |
| Electrical Box removing and disconnecting circuits | MikeT | Electrical | 9 | 08-15-2006 06:07 AM |
| Standard way to wire lighting circuits | robertc65 | Electrical | 9 | 03-08-2006 02:18 PM |
| Residential General Lighting Circuits | toastermaker | Electrical | 11 | 02-26-2006 01:04 AM |
| Using 12/3 to power Two Circuits | robertc65 | Electrical | 18 | 02-16-2006 12:26 AM |
