Trade: Electrical
Cutting In Lathe And Plaster
What are some of the ways you use to cut lathe and plaster, for bathroom fans, receptacles, etc....
I have a job coming up that has this and was wondering the best way to do this. Any input would be appreciated. |
Re: Cutting In Lathe And Plaster
A cheap dry diamond blade in an angle grinder,
or an expensive dry diamond blade in a roto-zip. No vibration so it reduces the chance of breaking the plaster keys.
Trade: Electrical Contractor
Carbide tile bits in a Rotozip, then switch to a regular bit if the lath is wood.
Long, straight cuts, I use a diamond wheel in an angle grinder.
Short straight cuts, I use a tile bit in a RotoZip. Regular box sized holes, like 3-3/8, 3-5/8, 4-1/8, 4-3/8, and 6-7/8, I use a Remgrit hole saw. Other miscellaneous cuts, I use the RotoZip again, with the tile bit. The Milwaukee sawzall blades made specially for plaster work half-decent in a hand saw if you're careful. |
Fentoozler
Here's my set-up...use it for many different applictions:
Rotozip (I recommend a CORDED model...I've burnt out too many cordless models) ![]() Circle Cutter ~ Rotozip #CRCT1 ![]() Vacuum attachment ~ Roto-zip #RZVAC1 ![]() Vacuum ~ Dewalt DC-500 Corded/cordless ![]() Just select the right bit - or combination of bits and off you go Carbide bit, then a wood bit for this lathe job. SWEET No mess...no clean-up...done
Service & Repairs
Trade: Electrician
AAAAlright!
That's it! You've been spending way too much time with Putty! ![]()
#8 | |
Baltimore Electrician
Trade: Electrician
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
The OP should be advised also that there are darned few bath fans that can be installed completely from below without having to hack bits and pieces off the outside of the housing. Hopefully, he has access from above also.
Trade: Union Electrician
God, I remember cutting this hole for a 1900 box and I was careful as a thief. I had one little piece of lathe sticking out and must have gotten impatient with it and pulled a little bit. Swear to God a three foot chunk of plaster came crashing down. The rest of the fishing went easy as pie. As a matter of fact the job was for a woman who is now my wife. How's that for lemonade?
#11 | |
Re: Cutting In Lathe And PlasterQuote:
I'm working in a house at the moment that has plaster that is 1-1/2" thick in total, and you can't break out even a little piece, even if you try hard. That stuff must have a lot of Portland mixed in it. Not so much fun. I have noticed that homes that went without central heating during some point in history tend to have plaster that is more likely to fall out in chunks like that.
#12 | |
It must have been your stripper, couldn't have been the dikes! ![]() ![]()
Master Electrician
Trade: Electrical
An old screw driver, hammer, and tin snips works good as well. Don't forget to tape the line you score with razor knife, sometimes it keeps the plaster from splitting back on you and sometimes it doesn't either.
#14 | |
Restoration Crazy
Two words:
Hardie Blade
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
| Patching Plaster & Sheetrock.... | Celtic | Drywall | 4 | 12-16-2007 09:25 PM |
| Fire rating lathe and plaster ceiling | adianz | Construction | 4 | 04-14-2007 07:02 AM |
| plaster problems | gemelli2 | Remodeling | 5 | 10-10-2006 06:49 PM |
| drywall over interior plaster/ brick walls | n8sr | Drywall | 10 | 11-10-2005 10:18 PM |
| drywal and lathe and plaster? | Humble Abode | Drywall | 24 | 05-14-2005 02:24 PM |
