Trade: Electronic Systems Contractor
Cutting Ceramic Tile?
Hey all, I'm a newby here. It looks like a great site for trade specific info. Here's my ? I need to cut a hole for retrofic can in a ceramic tile shower. Has anyone done this? What is the best way to do this?
Thanks, Rugger |
Trade: Residential Remodel
Re: Cutting Ceramic Tile?
4" grinder with diamond blade.
Maybe a mod will move to tile area for more responses. Richj |
Thom
Rich is correct. If you work carefully, you can undercut the hole then, using the side/edge of the blade, cut that to a perfect circle.
Caution, this is a really dusty process. You will have dust everywhere. Lots of cleanup. Don't forget your safety glasses and respirator. |
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
I belive "Roto zip" makes a tile bit.
Electrical Contractor
Trade: Electrical
Grinder??? C'mon. That is so 70's.
![]() For anything but floor tile (read: harder than diamonds) a Rotzip with the carbide bit. You'll wonder how you ever got along without one. YES, VERY dusty!!
Well, guess I'm a 70's guy then. Love my grinder.
Rich P.S. Touch a wet sponge to the wheel while grinding to keep the dust down or vacuume as you go. |
Philadelphia electrician
I have also used a jigsaw with an abrasive blade
[I am not that good with a rotozip ..]
Philadelphia electrician |
Trade: general household repairs
What size hole and what shape? I have carbide grit hole saws in 1" and 2" that just go in a drill. They come from the tile shop. To drill a small hole use a hammer drill! Seriously, go VERY slowly. I have drilled many 5/8" holes for electric wires. Start with the bit going "tick, tick tick". Takes about three minutes per hole. A blob of toilet bowl wax keeps the bit from skidding.
For large square holes use a grit blade in a sawzall. Drills and sawzalls MUST be variable speed, and run them slowly. Use diamonds on marble. |
Chief Toilet Mover
Trade: Bathroom Remodeling
The grinder is a tile man's 3rd best friend, right behind his wet saw and his breaker board.
Trade: Electrical
I didn't mean to poo-poo the grinder all together. I carry one on the truck full time with about 25 wheels.
It's just on soft tile I love the Roto.
3rd gen,it's in the blood
Trade: roofing
rotozip.way faster than grinder,and much nicer.
You have ONE advantage over me.....you can kiss my butt and I can't!! |
Thanks for the input. Just got back with my new Roto-zip. Can't wait to use it. Ain't it great to get new tools?
Rugger |
Union Electrician
Trade: Inside Wireman
I'd try it on a scrap piece first so you get a feel for it before attempting to 'ruin' someone's tile job.
I've used a roto zip while installing travertine, and am curious if it also works on ceramic tile? It's great for those cuts around the toilet. |
| ceramic tile vs quarry tile labor | t336 | Flooring | 2 | 07-18-2007 08:00 PM |
| Ceramic Floor tile grouting | John Walls | Flooring | 9 | 05-18-2007 07:42 AM |
| ceramic tile | pre-reno | Flooring | 10 | 02-04-2007 04:15 PM |
| ceramic tile over tile? | Grumpy | Remodeling | 19 | 09-10-2006 07:34 AM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
