Trade: electrical
Cuiting Ceiling Sheet Rock Between Floor
What is/are the best tolls to use to cutting ceiling and notch floor joists to run wire from one side of the wall to another side?
Thank you in advance. Louis |
Repair/Remodeling Tech.
Trade: Repair and Remodeling Services
Re: Cuiting Ceiling Sheet Rock Between Floor
It's against code to "notch" floor joists or studs for 120/240V wiring. The wire has to be 1 1/4" away from either side, which on a 2x4 that's pretty much in the center. At any rate, you can't notch for a wire and cover it with sheetrock, if that's what you're asking.
I've never needed to pay a toll to fish wires.
If there's an attic above, run the wires up there. If there's a room above, pry up a floorboard or piece of plywood and drill through the joists if running perpendicular. If running parallel, I use fiberglass fish sticks or a piece of stiff #4 solid ground wire to fish from A to B. |
Trade: Renovations
I just did that when putting in a new bthrm fan. I cut rectangular pieces out of the ceiling between every second joist (use a studfinder) with the tool that drywallers use for cutting elec. boxes out (Zipquick, or the like). Save the pieces. Reach in with a drill and drill your holes for the wire at the center of the joists. You risk drilling into existing wires so you might want to put an access every joist, that way you can see both sides. Pull your wire. Slide a piece of plywood into the hole and screw it down over the opening, then screw the drywall piece back into place. Tape, mud, sand. Now you're an electrician and a drywaller.
#5 | |
Trade: commercial - residential remodeling
Re: Cuiting Ceiling Sheet Rock Between FloorQuote:
I find it easier to use a 6" hole saw for the access hole |
#6 | |
Trade: builder remodelor
#7 | |
#8 | |
#9 | |
Trade: Renovations
Bob, I find it easier (at least with my drywall skills) to refinish a square hole. Doubtless it's faster to cut a round one. Rich
Custom Builder
Bob said hole saw Rich, can't get any quicker than that.
With a flash patch a 6" round hole can be gone in about 30 min, including paint. Bob
Bob |
I use the cut out. screw it back to the 2x with a couple of drywall screws and tape. if your in a hurry use 20 min. mud.
30 min. to finish including paint is great my hats off to you |
On the odd occasion where I need to make a hole that needs patched, I just point to it and tell the homeowner, "you'll have to get someone to patch that for you". That is much quicker than 30 minutes for me.
#14 | |
Custom Builder
If you use the same holesaw, cut most the way through some scrap from the back, brake away the ouside of the hole, leave some face paper, no tape needed, Flash Patch, and it fits right in snug because the width of the holesaw gives the perfect play.
Bob Quote:
Bob |
#15 | |
http://www.tr-built.com |
#16 | |
#17 | |
#18 |
Trade: Renovations
Talk to me re. this flash patch, Bob. Rich
#19 |
Trade: Renovations
No doubt on the hole saw, Talk to me re. this flash patch, Bob. Rich
oops, sorry Last edited by reveivl; 06-18-2005 at 11:58 PM. Reason: double message |
#20 |
Custom Builder
OK,
Drywall face paper = side A Drywall back paper = side B With a good utility knife, cut your hole exact on side B and score down most of the way through the drywall. Cut your hole about 2 inches bigger all the way around on side A just cutting through the paper good. Flip back to side B and cut from the exact line out in all directions. Brake and seperate drywal from paper on the ouside of your beautiful new flash patch. I hope that helps, if not maybe I'll cut you one and upload the images after church today. No promises though, Judy wants me to help her paint the guest bedroom. Bob
Bob |
| No Glue Sheet Floor | dayspring | Flooring | 35 | 10-02-2008 02:58 PM |
| Pex - ceiling or under floor | Hardibuilt | Plumbing | 4 | 04-24-2007 10:25 PM |
| new sheet rock a little wavy | drivewizard | Construction | 26 | 12-31-2006 10:14 PM |
| Basement floor dilemma | ron schenker | Flooring | 11 | 07-02-2006 09:36 PM |
| green sheet rock and adhesives | hhs2006 | Drywall | 1 | 04-17-2006 04:06 PM |
