Home Depot aisle walker
Trade: home remodeling
Could Hot Aluminum Fascia Run Power Bill Up?
Bumped into a roof corner and got shocked
Turned out the neutral wire to security light was hot, hot was hot too and home owner couldnt remember when security light quick working as soffit guys and electrician were close together.Old 20-30's house with 3 generations of electrical married together, I found the feed to the light and disconnected it, homeowner doesnt need it. Anyway I couldnt shut down the whole house and see if power was bleeding but I wonder. House is stone, didnt check to see what else on the house was hot. HO complained of high bills, wasnt a dead short or would have breaker. Puzzle was why would the switched power work while the neutral stayed hot and the breaker killed both. What do you think, was this a power drain? |
Service & Repairs
Trade: Electrician
Re: Could Hot Aluminum Fascia Run Power Bill Up?
The "neutral" in a 2-wire 120 volt circuit is a current-carry conductor. It carries the same amount of current as the "hot" conductor. Yours seems like a classic example of what happens when someone wires a GFCI ground wire directly to a copper pipe... OR... someone instead of using a neutral at the GFCI, picked up a ground directly from a metal box and used it as a neutral. It's called OBJECTIONABLE CURRENT FLOW and now you know why it's called objectionable - because you shouldn't be getting shocked touching a fascia board.
No GFI's in the house, liscensed electrician had put in a new panel so HO could have new heat/air system and fed existing panel. If I were electrician I dont think I'd do jobs like that. Also fixed 3 outlets hot wrong side, lot of hacks out there.
Service & Repairs
Trade: Electrician
GFCI or not you have objectionable current flow and it's likely caused by a bond somewhere other than in the main disconnect.
"Also fixed 3 outlets hot wrong side, lot of hacks out there." that's where I would start looking first. |
#5 | |
Re: Could Hot Aluminum Fascia Run Power Bill Up?![]() Quote:
, couldnt find where the neutral was coming from, light did work at one time. I killed the circuit, checked rest of house, end of story.What I'm curious of is since the entire fascia and inside perimeter of soffit was hot could it have been a current drain? HO thought it was funny when I mentioned that he could have been just plugging his christmas lights into the roof. Last edited by willworkforbeer; 06-24-2009 at 04:49 PM. |
Service & Repairs
Trade: Electrician
Yes, what you mean by current drain I really have no idea but yes the circuit was using the aluminum fascia to return current to the source in which it came from. Now that path has been broken and that's why your light isn't working.
#7 | |
Re: Could Hot Aluminum Fascia Run Power Bill Up?Quote:
If you dont know what a current drain is I dont know how you could be an electrician. ′kər·ənt ′drān) (electricity) The current taken from a voltage source by a load. Also known as drain. Last edited by willworkforbeer; 06-24-2009 at 05:09 PM. |
strat hd
Trade: framing contractor , remodeler , GC occasionally
I just got the popcorn going.........
| The Following User Says Thank You to strathd For This Useful Post: | fez-head (06-24-2009) |
#9 | |
Service & Repairs
Trade: Electrician
Re: Could Hot Aluminum Fascia Run Power Bill Up? |
Service & Repairs
Trade: Electrician
Breaker off, problem solved.
Service & Repairs
Trade: Electrician
How did you solve the problem when you don't even know what you're talking about?
ampman
Trade: providing pathways for electrons and protons
i must have got here late
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
Service & Repairs
Trade: Electrician
See if strathd will share his popcorn with you.
strat hd
ampman
#18 | |
#19 | |
Trade: electrician Phoenix AZ
Light didn't work. No power consumed.....until you touched it ![]() Power was going to the light, thru the light and TRYING to get back to "ground" via the metal facia. Path/circuit wasn't complete until you completed it. You must have been grounded somehow.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
#20 |
ampman
when you showed up on our job and claimed electronics knowledge all you got was the shovel
| Aluminum Fascia | eglanc | Windows, Siding and Doors | 38 | 05-02-2009 11:41 PM |
| aluminum soffit and fascia | Something new | General Discussion | 11 | 05-01-2009 07:43 PM |
| wanted: Aluminum Fascia Roller | jcalvin | Tools & Equipment | 38 | 02-05-2009 04:00 PM |
| Estimating Aluminum Soffit and Fascia | DaNortWoods | Roofing | 7 | 07-14-2008 10:41 AM |
| How do you guys attach your aluminum fascia? | dkillianjr | Windows, Siding and Doors | 30 | 11-14-2007 08:05 PM |
