Cost To Hook Up Xfer Switch
Hi, I have a 10 circuit manual transfer switch that I need to tie into my main panel. I will only be using 7 circuits, I have mounted the switch to the wall and identified where everything is to be be hooked up. I just need to have an electrician come out and hook it up, my guess is that it should only take maybe and hour or two. Does anyone know roughly what this could cost? (Boston area) Thanks.
Eater of sins.
Trade: Designer/Drafter Extrordinaire
Re: Cost To Hook Up Xfer Switch
$500.00 and a smile.
I certainly hope this is of help to you. Andy.
www.draftinginoc.com |
#3 | |
You did what??
Re: Cost To Hook Up Xfer SwitchQuote:
Trade: Electrical
Re: Cost To Hook Up Xfer Switch |
You did what??
Re: Cost To Hook Up Xfer Switch You're right, I didn't even notice that...
You did what??
To the op, so there are no hurt feelings...
And I do electrical, too!
'Twit tree fiddy and tree billion.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: Consultant
An hour or two, huh? Yeah, I guess you did do the hard part- you know, mounting it on the wall and labeling it and stuff. I'm thinking a good electrician can probably whip the rest of it out in around 30 minutes, so even at an hourly rate of $90/hour, you should be looking at around a $45 bill.
Post this info on your local Craigslist page and you should get plenty of eager respondents. |
#9 | |
Fentoozler
Contractor Talk... What's the difference? OHHHHHHH!
#10 | |
Electrical Contractor
Trade: Electrical
![]() Try $105 for a service call.
I don't even grab my van keys for anything less than a c-note.
Trade: Electrical
Unless it's digging a ditch it usually costs more for the HO to do the work and have me check it. Most times no thought has gone into mounting boxes so that conduit can be installed neatly, etc.
I also don't depend on the HO to tell me where everything should be hooked up. If you are in the trades, surely you have ran across an electrician you can trust to do the work. As a tradesman yourself you should understand the VALUE of having it profesionally installed. |
Trade: Consultant
You obviously missed the veiled sarcasm in the post. I don't pick up the phone for less that $200, and if I have to leave the house or think too hard, it's at least $300.
You did what??
... and that's just for his baby-sitting gig
#15 | |
Trade: Electrical
![]() Sorry.
| Cost of Geothermal Units | orson | HVAC | 38 | 01-13-2010 08:56 AM |
| cost plus % contract | chaney | Business | 10 | 03-17-2009 03:58 PM |
| Dressing up a house with low cost. | J-Peffer | Windows, Siding and Doors | 15 | 06-11-2008 10:37 PM |
| Heil furnace static switch | ronnyd | HVAC | 0 | 04-13-2008 09:30 AM |
