Correct Wiring For An Electric Dryer In An Old Home - Electrical - Contractor Talk
Old 11-29-2011, 04:35 AM   #1
rstarre's Avatar
Rewards Points: 93
I am remodeling an old home. The electric panel was upgraded by the home owner to 200 amp service back in 1991. The electrician ran an electric outlet in the laundry room for an electric dryer, just in case the home owner ever want to switch from her gas dryer to an electric clothes dryer. Well now she wants to make the change. My question is the wiring. I know it should be a 30amp double circuit breaker, wired for 220 & a no. 10-3 wire with a bare ground. The thing I am not sure about is the electrician used 10-2 wire with a bare ground. I know the electric code for heavy appliances was changed in 1993. So was the 10-2 wire the correct code prior to 1993? The way it is wired now is the black & white are connected to the double 30 amp circuit breaker in the panel. The white wire has black tape & tag noting it is being used as hot instead of neutral. The bare copper wire is being used as the white, and is connected to the side bar in the panel where the other white wires are connected. Was this the correct way to do it or was this code before 1993? I do not want to plug the new dryer in unless I am sure this is ok. I can also ground the dyer by running a ground wire from somewhere on the exterior back of the dryer to a water pipe for the wash machine.
rstarre is offline
Old 11-29-2011, 06:59 AM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,780
Re: Correct Wiring For An Electric Dryer In An Old Home
Hooking 10-2 up to a dryer today would be a violation.
Why is there not a Flat Mars Society?.
480sparky is online now
Old 11-29-2011, 08:20 AM   #3
rstarre's Avatar
Rewards Points: 93
Well it is up to the home owner if she wants to plug that electric dryer in. I haven't moved the dryer outlet box or disconnected any wiring from it.
I noticed it when I took the front panel off the box to paint. According to the home owner, it was done prior to the change in code. Was that the proper way to wire it back then?
rstarre is offline
Old 11-29-2011, 10:04 AM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,420
The code allowed you to use the bare conductor as the neutral?
And no grounding conductor?
Inner10 is offline
Old 11-29-2011, 10:32 AM   #5
Kgmz's Avatar
Yes and No. At one time a 3 wire dryer outlet was allowed and 4 wire outlets were only required for mobile homes. I believe this changed with the 1996 NEC.
As for using the ground as a neutral, back then a lot of dryers were 240 volt everything heater, motor, etc. so no neutral was needed. Some would have 120 volt timers but that was allowed, if I remember right as the NEC stated something as long as the are no objectionable loads on the ground. Eventually manufacturers started going to 120 volt motors to save money and thats when the code was finally changed to address this.
Kgmz is offline
The Following User Says Thank You to Kgmz For This Useful Post:
Inner10 (11-29-2011)
Old 11-29-2011, 11:01 AM   #6
rstarre's Avatar
Rewards Points: 93
So if she has a newer dryer, it will work properly on the the way it is wired now?
rstarre is offline
Old 11-29-2011, 11:04 AM   #7
Inner10's Avatar
In theory it will work fine but it won't be grounded too well.
Inner10 is offline
Old 11-29-2011, 04:01 PM   #8
rstarre's Avatar
Rewards Points: 93
Thanks
rstarre is offline
Old 11-29-2011, 04:33 PM   #9
Kgmz's Avatar
This why dryers do not come with cords. And most appliance stores that come to deliver and install them usually bring both a 3 and 4 wire cord.
Kgmz is offline
Old 11-29-2011, 04:45 PM   #10
480sparky's Avatar
It will be grounded, but it's not as safe as a 4-wire feed.
The Following User Says Thank You to 480sparky For This Useful Post:
skyhook (11-29-2011)
Old 11-29-2011, 09:48 PM   #11
SemiRetiredEL's Avatar
Trade: Electrial Contractor (master)
Rewards Points: 75
The groundwire may need to be jumpered to the neutral so the 120V timer etc. will run.
SemiRetiredEL is offline
Old 11-30-2011, 04:03 AM   #12
txgencon's Avatar
Rewards Points: 430
I wonder how many times the other sparkies get a call from a new homeowner wanting the receptacle changed to a three prong receptacle to accomodate their old dryer. Seems like it happens about half the time with me. Most homeowners can't grasp the concept and think I installed the wrong receptacle.
txgencon is offline
Old 11-30-2011, 05:54 AM   #13
mrmike's Avatar
Trade: Electrical & Carpentry
Don't even think twice about it- Tell your Customer that the Wire needs to be changed out to be SAFE !!!
Usually, if it is on the first floor & it is beeing remodeled- it should be a piece of cake !!
mrmike is offline
Home Builders -how to talk to the correct person for my services? RacerX780 Marketing & Sales 4 04-11-2010 02:12 AM
USDA Home Loans - Rehab Funds renet General Discussion 0 10-02-2009 11:00 PM
Question On Home Automation System degmsb General Discussion 3 09-21-2009 01:26 PM
Log Home Advise Lew Construction 1 08-12-2009 07:54 PM
