Trade: Exterior Remodeling
Confused About Fuses
I have a hot tub that has a 2 stage pump motor for the front jets and a 1 stage pump motor for the rear jets. The front motor stopped working and I removed both fuses and went to my local electric supply house. Both are Buss fuses and are SC 25 amps. However they both have a different number on them. The front fuse is FP27-51 and has a green label. The rear fuse is FP30-26 and has a blue label.
Problem is the electric supply guy says the front one isn't in stock and if he orders it for me I have to buy 10 fuses for about $8.00 each. The other one is in stock and I can buy just one for $6.60. Can someone explain the differences? They are both the same size and are 25 amps. Why couldn't I just buy 2 of the FP30-26? How dangerous would it be to use 2 30 amp fuses? Thanks for any help. |
Trade: Painting, flooring
Re: Confused About Fuses
I'm not an electrician but I doubt any electrician will answer your question. I've always followed the 'don't f'in ever put in a higher fuse than was previously in the doohicky holemabobber before' and the corollary 75.12 a "always use the same part you took out when you put it back in."
Too much amperage could cause a fire, destroy the pump, fry electronics, maybe electrocute someone or work just fine. The bads out weigh the goods in my book. |
Service & Repairs
Trade: Electrician
Contact the manufacturer and ask them. Once you go messing with the UL listing it's relatively downhill from there. One's blue, and one's green likely because of the stages in the heating element. Who knows, maybe the manufacturer will send you the fuse for nothing or send out a technician or something. The tub is UL listed, right?
Electrician service in Rahway, Cranford, Clark, Westfield, Mountainside, Scotch Plains, Fanwood, Roselle, Roselle Park, and New Jersey | Same day electrical service and repairs | Licensed and Insured Electrician in Rahway Last edited by Magnettica; 02-03-2009 at 01:13 AM. |
I'm not planning on using a 30 amp fuse. My question has more to do with why I couldn't use any 25 amp SC fuse. I don't understand why the manufacturer did'nt just use the same fuse? And what is the difference between the two 25 amp fuses I referenced?
Service & Repairs
Trade: Electrician
I meant to say pump motor, not heat element.
Why are they two different colors? I have no idea other than ratings for that specific fuse. |
#6 | |
Re: Confused About FusesQuote:
Service & Repairs
Trade: Electrician
Have you asked to speak to service people?
Sales people could careless because your tubs already been sold. |
woodchuck2
I would try another supply store or local hardware store that may carry such fuses. I know my local hardware has them in stock. Heck Lowes or Home Depot may even have them.
Trade: General Contractor, Electrician
I think that might be a time delay fuse... Probably takes into account for a greater starting load. You could probably put the regular one in, but I doubt it would last long.
Trade: Electrical & Carpentry
Archania is exactly right . That fuse probably is sized to to give the motor max protection for the FLA (full load amps) yet is a time delay to allow enough time for the starting current-------there are many many types of fuses in industry that we had to pay attention to the #'s for particular situations ,(time delay) quick blow) etc. You could not just replace a 25a with any 25a on the shelf.....hope this helps..............Mike
I would check At the Pool/spa places around your area for them. There also is an Ebay site that sells them (Gecko Electronics/Spa) Good Luck! Last edited by mrmike; 02-04-2009 at 07:38 AM. |
Pompass Ass
Re: Confused About Fuses |
SoCal electrician
Trade: electrician
Did you do a resistance/continuity check on the fuses to verify they were bad? If so you still need to figure out what is causing them to blow. I would recommend having a qualified repair person diagnose and fix it.
#13 | |
As it turns out, it wasn't the fuse. The impaller on one of the pumps had broken off and that's what was causing the pump not to circulate water. So now I've gotta go out and remove the pump and replace the impaller when it's 20 degrees and windy.
#14 | |
Thom
Trusting the word of a clerk is like playing the powerball lottery, there's a one-in-a-billion chance it will be right. |
| The Following User Says Thank You to thom For This Useful Post: | bwalley (02-05-2009) |
Service & Repairs
Trade: Electrician
Couldn't have said it any better Thom.
Ha, and they are probably the same guys that do the "how to" clinics on the weekends...
| im a sub receiving 1099's from the GC's im confused and need help. | kc brick layer | Business | 26 | 02-05-2009 09:25 PM |
| Confused Master Plumber | pydoplumbing | Plumbing | 20 | 01-09-2009 06:50 PM |
| Still confused on the SDS options. Please explain | safehouse | Tools & Equipment | 8 | 02-24-2008 11:59 PM |
| Subwoofer fuses keep blowing. | Chris G | Electrical | 10 | 11-22-2006 10:07 AM |
| Where do I start? Confused?? | brax | Contractor Licensing | 2 | 08-28-2006 05:04 PM |
