Trade: roofing
Conduit Under Roof Deck
Is there a conduit finder out there that we can use to trace conduit under a roof deck?
Electrical Contractor
Re: Conduit Under Roof Deck
I've used my cable tracker to trace out conduits. I had to hook on the wire(s) in it though.
Cable locater |
#3 | |
And I do electrical, too!
Re: Conduit Under Roof DeckQuote:
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Never know, could be one of those roofer/electricians. Just doing roofing cause the electrical is slow
#5 | |
| The Following User Says Thank You to 480sparky For This Useful Post: | ampman (06-05-2009) |
#6 | |
Fentoozler
Why?
ampman
Trade: providing pathways for electrons and protons
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
Fentoozler
I really wanted an answer/explanation from the OP.
Why couldn't one of the
underground locate guys do it? I had one trace water lines in a slab once.
#10 | |
Fentoozler
It might have something to with the continuity between the EMT and the trusses/deck pan...and everything else metal in the building [it's all bonded together]
#11 | |
Never thought of this particular problem either though.
ampman
sorry i blew up like that
See this thread on ElectricianTalk. It happens from time to time, and I think the only tool that any roofer has to avoid it is luck and a decent insurance policy. I think it's fair to say that if you do flat roofs, this is going to happen from time to time.
http://www.electriciantalk.com/f2/sc...conduits-7205/ |
#14 | |
Trade: electrician Phoenix AZ
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
Trade: roofing
This job is in a Milk plant and the conduit is run every where. Instead of having a man stand below all day with a radio we were hoping to trace them above the deck and save some time.
| Bison deck supports for roof deck | Chris G | Decks & Fencing | 20 | 11-17-2010 05:36 PM |
| Icyene under roof deck vs. cellouse or fiberglass above the ceiling. | D. Boone | Insulation | 6 | 10-24-2008 08:22 AM |
| Patching penetrations in concrete roof deck | geecee | Concrete & Paving | 1 | 03-04-2008 03:34 PM |
| Need help designing Roof for addition | jaymay75 | Framing | 21 | 06-17-2006 10:47 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
