Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 04-08-2006, 10:53 AM   #1
coolmen's Avatar
Trade: hvac
condenser wireing
I have a homeowner who wants his a/c moved 20 ft from where it is.building a deck.the only way i see is to reroute lineset and wireing is from under ground.Is it acceptable to wire nut in from the existing disconnect box a new high voltage line that is of course protected in under ground conduit.I normally would run a new line from the panel box but in this case it is very diffacult.
coolmen is offline   Reply With Quote
Old 04-08-2006, 11:31 AM   #2
Electrical Contractor
Trade:
I would not wirenut but split bolts may be what you are looking for.
stars13bars2 is offline   Reply With Quote
Old 04-08-2006, 11:57 AM   #3
Electrician
Trade: Electrician
Why not just pull new wire from the panel, through the old discon., to the new discon.?
fridaymean is offline   Reply With Quote
Old 04-08-2006, 05:47 PM   #4
coolmen's Avatar
Trade: hvac
thanks guys ill use the old disconnect box and and bolt together.Run underground 15ft to new disconnect,a/c area
Old 04-08-2006, 07:08 PM   #5
Speedy Petey's Avatar
Trade: Electrical
What size is the wire? It would be crazy to split bolt anything smaller than #6. Even two #6's can fit in a large blue wire nut.
Speedy Petey is offline   Reply With Quote
Old 04-10-2006, 04:33 PM   #6
coolmen's Avatar
Trade: hvac
3 ton airconditioner 13 seer minimum ampacity 20/20 with 30amp max breakers. Im thinking #8 or is #10 pushing it
Old 04-10-2006, 10:35 PM   #7
McElectric's Avatar
Trade: Electrical Contractor
Article 312.8 of the 2002 NEC allows you to splice these condutors in the disconnect. Be sure to size the conductors to the minimum ciruit ampacity shown on the label on the unit.
McElectric is offline   Reply With Quote
Old 04-11-2006, 09:06 PM   #8
Romex-Racer's Avatar
Trade: Electrical
Cool
Can you see the old disconnect from the new condenser location?
Whoop! Whoop!
Romex-Racer is offline   Reply With Quote
What are bulkheads FleshnerDrywall Drywall 12 02-23-2007 07:51 AM
A/C (condenser) Bands Rating Unregistered HVAC 3 06-10-2004 07:59 PM
Contractor Talk™ © 2003 - 2010 The Building Network LLC
