Compressor Tripping Breaker
Old 03-03-2005, 01:44 PM   #1
kmd's Avatar
I read the post about the compressor and I am having a similar problem, I bought a sears compressor 115V 15 amp it says on the unit. I plugged it into an outlet and it trips the breaker automatically. I plugged it into an 20 amp circuit that I know nothing else is hooked to and it automatically trips the breaker as soon as the compressor starts up. I understand the problem that initial fist second or two it probably draws 25 to 30 amps then it will only draw 15 amps. The instructions say use a time delay fuse, I have not had anything done to it but If I have a 20 amp circuit the a 15 amp time delay fuse when it starts up wouldnt the breaker still trip? What is the proper way to set this up? do they make time delay breakers?
kmd is offline
Old 03-03-2005, 07:14 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Compressor Tripping Breaker
Breakers are time delay.
If it trips the instant the compressor tries to start there is either something wrong with the compressor or the breaker is weak.
This unit should work fine on a 20 amp circuit. Contractors use them every day.
Speedy Petey is offline
Old 03-04-2005, 08:03 AM   #3
kmd's Avatar
I have taking the compressor back twice I am on the 3rd compressor and they all do the same thing, it is plugged into a dedicated 20 amp breaker, and I have changed the breaker
kmd is offline
Old 03-04-2005, 09:01 AM   #4
stars13bars2's Avatar
Is this receptacle and compressor the only thing on the breaker ? Does anything else go off when the breaker trips ?
stars13bars2 is offline
Old 03-04-2005, 01:36 PM   #5
kmd's Avatar
I am 100% positive this is the only outlet on the breaker it is in the garage 5' from the panal and I had this line put in several years ago for a 110v mig welder that I have. I have replaced the breaker thinking it is bad and I am on my 3rd compressor, its driving me crazy any suggestions? Somebody told me I should put a 30 amp breaker in but I dont want to put a 30amp breaker on a #12 wire.
kmd is offline
Old 03-04-2005, 03:34 PM   #6
Try plugging it in another receptacle, and see what happens. That should eliminate something. It is either a bad receptacle/circuit or a bad compressor, or it just will not start on a 20amp breaker circuit. Take it one step at a time.
Old 03-07-2005, 11:59 AM   #7
techmexs's Avatar
Lightbulb
First things first. Check your electrical outlet. Make sure your wiring is done right. If the compressor needs a safety ground make sure your outlet has one.
On the electrical panel replaced the braker with a good known braker. Isolate your problem. Plug your compressor into different outlets. Check your wire size on all outlets. Hope that helps you. Keep up the good work.
Viva Texas.
techmexs is offline
Old 03-18-2005, 09:54 PM   #8
I tried to warn people about doing their own electrical work, but now it seems that the worst must have come to pass. It seems that KMD has succumbed to thrill of doing ones own electrical. If not, surely he could have told us what happened when the unit was plugged into another receptacle. Inquiring minds would like to know.
Hot dryer breaker HandyAl Electrical 7 08-19-2008 05:34 PM
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
gfci breaker Browny Electrical 6 05-29-2006 07:45 AM
Breaker Sub Capt Electrical 3 12-30-2005 08:18 AM
