tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Compatible Circuit Breaker
Old 03-19-2011, 01:05 PM   #1
dcapone's Avatar
Trade: Low Voltage Installation
Rewards Points: 91
Adding a new circuit for a new room in the house and have an ITE G3030MB1-200 breaker box.
I am hoping to be able to pick up an Arc-fault breaker at a local Lowe's / Home Depot, however, the choices ar elimited.
Is their some type of table that lists what manufacturer/type of circuit breaker would be compatible with this box. In my parents house and my brother's house, there was a listing of compatible breaker types and models listed on the inside cover of the box, this box does not have any such listing.
dcapone is offline
Old 03-19-2011, 01:09 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 9,904
Re: Compatible Circuit Breaker
Siemens AFCI circuit breakers are suitable for use in existing products manufactured by I-T-E, Gould, Siemens-Allis and Siemens Industry. Specifically the AFCI circuit breaker types can be used in any of these products in accordance with the following table.
Breaker Type Marked on Panelboard... AFCI Breaker Type That Can Be Used
QPF.................................................. ..QAF
QPHF ..................................................QAFH
BQF.................................................. ..BQAF
BQHF ..................................................BQHAF
BLF.................................................. ...BAF
BLHF.................................................. .BAFH
Chuck Norris can start a fire by rubbing two ice cubes together.
480sparky is online now
Old 03-20-2011, 04:19 PM   #3
accuratejoe's Avatar
Trade: Licensed Contractor in TN,Electrical Hvacr
to be in code you need to use ite breakers, making something fit might work but if there is a problem or fire down the road and you have wrong breaker installed guess what, not good. If you dont belive me call up your inspection dept and ask
accuratejoe is offline
Old 03-20-2011, 10:19 PM   #4
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Or just use Siemens.
DuMass is offline
Old 03-20-2011, 10:20 PM   #5
DuMass's Avatar
Trade: EC
But where will you find that ITE AFCI cb to be in code?
DuMass is offline
Old 03-20-2011, 10:29 PM   #6
You lose underwritors listing by not using correct material
Old 03-20-2011, 10:40 PM   #7
DuMass's Avatar
Trade: EC
Siemens purchased the old ITE brand years ago and they have stated that their cbs are suitable for use in ITE panels, just like CH states that their BR cbs are suitable for use in Bryant panels.
DuMass is offline
Old 03-22-2011, 12:00 AM   #8
Al13Cu29's Avatar
Trade: Electrical Contractor
On the packaging for Siemens (and Murray) Arc Fault Breakers, it lists the other brand names that they are compatible with. They are ITE and Course-Hines.
There are many circuit breaker brands that has been bought out by other companies. You will find that a breaker will fit many different brand panel. Just need to check if one brand circuit breaker is allowed in another brand panel.
If you don't have time to do it right, when will you have time to do it over?
Al13Cu29 is offline
Old 03-26-2011, 10:42 AM   #9
dcapone's Avatar
Rewards Points: 91
Does the last post indicate that a Murray AFCI breaker should be suitable to use in this box as well?
I have been having a heck of a time finding a place in RI that carries Siemens AFCI breakers (including the couple electrical places I know).
I have found Murray just about everywhere. If the Murray would not work as well, if anyone knows a place in RI / southern MA to grab a Siemens AFCI, it would be appreciated.
dcapone is offline
Old 03-26-2011, 10:52 AM   #10
dcapone's Avatar
Rewards Points: 91
Actually, I've been specifically looking for Siemens QAF, however, I see this breaker matches the original "QP" type.
Would this be a suitable breaker...http://www.lowes.com/ProductDisplay?...ow&cId=PDIO1#?
dcapone is offline
Old 03-29-2011, 09:20 AM   #11
dcapone's Avatar
Rewards Points: 91
any confirmation would be greatly appreciated.
dcapone is offline
Old 03-29-2011, 09:32 AM   #12
480sparky's Avatar
My list is direct from Siemens web site. Don't know if that's enough 'confirmation'.
Old 03-29-2011, 10:49 AM   #13
dcapone's Avatar
Rewards Points: 91
Hi Sparky,
I fully trust your list, however, as mentioned in one of my earlier posts, I am having trouble finding a big box store or even a electrical store in RI that stocks Siemens QAF type breakers. The breaker I linked to on the Lowe's site does not indicate QAF on the package but indicates it as a "QP" type. In reviewing your list and the naming strategy's of other brands, it appears that the change from QPF/QPHF to QAF/QAFH is essentially for the "A" meaning arc-fault in the same class of breaker.
I am therefore assuming that if you have a breaker listed as a "QP type" arc fault breaker that it is basically a QAF breaker despite the packaging calling it "QP type" instead of "QAF".
Note, the box uses QPF/QPHF breakers.
dcapone is offline
Old 03-29-2011, 10:53 AM   #14
480sparky's Avatar
Another option is to install a small (6- or 8-circuit) subpanel next to the main panel. Feed it with a 2-pole breaker in the main, and then you're 100% whatever AFCIs you put in the sub are compatible.
Circuit Breaker Broken? Bob Deb Electrical 2 11-18-2010 10:32 PM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 10:39 PM
Frank Thomas circuit breaker. K2 Electrical 13 01-22-2009 09:13 PM
New Basement Circuit dcapone Electrical Picture Post 16 09-30-2008 04:13 PM
circuit breaker panel spatial requirements Jefe Electrical 1 04-06-2008 09:16 AM
