Commercial Temp Lighting?
I'm in charge of keeping a couple thousand feet of sting-o-lights going. Incandescent bulbs, plastic cages that melt when they touch the bulb, broken cages...... I keep thinking there has to be something better out there that is OSHA approved. Anybody using something a little more bullet proof???
Thanks.. |
And I do electrical, too!
Re: Commercial Temp Lighting?
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#3 | |
Fentoozler
Re: Commercial Temp Lighting?Quote:
Yup....just don't stay too close to them for too long w/o SPF100 on
ampman
Trade: providing pathways for electrons and protons
i was reading somewhere that if a m/h was used inside the bulb had to have (i think ) internal sheilding in case of rupture
Don't use those plastic cages and use CFL's.
Check out the Duraline construction strings. |
#6 | |
Special lamps are avaible for just a use. They are designed to keep the outer jacket of the lamp intact in case of rupture. They are called Type O lamps.
I save old high bays from retrofit jobs and use them as temp lights. Sometimes your temp lights get entombed, and that's okay with me if they're otherwise freebies.
The ceilings are too low for hid's on the current job. I was hoping someone had some osha info on cf's, shatterproofs, or better yet, shatterproof cf's. I try to get in some discussion with the safty guys about better lighting but they seem to think the old way is just fine. Could probably save them money on labor, bulbs, and cages and they have a couple more phases on this project alone. Oh well.. I'll keep working on it. Thanks..
Duraline has the shatterproof CFL's, and shat-r-shield has them also.
ampman
any links of course i ask this with out knowing how to post links
Duraline, look under temporary lighting.
http://www.jbn-duraline.com shat-r-shield http://www.shattershield.com |
Trade: electrician
Re: Commercial Temp Lighting? |
Trade: Commercial Electrical Inspector
Temporary power on a commercial job is a pain in the a** regardless of what you use.
I used the high bay method if I had the ceiling height,if not then good old fashioned stringers with clear 100 watt bulbs. I even have one of those temp. 400 MH hanging in my shop at my house for those times when the regular lights are not quite enough |
Trade: electrical contractor
wobble light they are bullet proof and sit on the ground about 3 'tall and wobble when you hit them
On a few jobs I did , I used 1500 watt quartz lights
| Commercial Construction Spreadsheet Help?? | SBI | Commercial Construction | 16 | 12-17-2010 11:17 AM |
| Commercial Drywall work Galveston, Texas | Preston259 | Drywall | 0 | 12-21-2008 05:59 PM |
| Residential General Lighting Circuits | toastermaker | Electrical | 11 | 02-26-2006 01:04 AM |
