Trade: Plumbing & Electrical
Commercial Recepts
With the leniency given to the amount of recepts in commercial applications, how many utility/unknown load recepts do you do per breaker. As a rule of thumb, I'm privy to 4 per 20A. U?.
Re: Commercial Recepts
Depends on the type of occupancy. For commercial type work, you're limited to calcs at 180va per yoke. You're proposing less receptacles total than that calc allows, and that's totally fine. It might blow your bid out of the water if you're competing for the job. If it's T&M work, or "design-build" as they seem to want to call it in the commerical world, I just take into account the occupancy type and the use that these receptacle circuits might be put to in the future. More of a visceral feeling than any rule of thumb.
#3 | |
Re: Commercial ReceptsQuote:
On this one large job I have going the owners were veeeery particular on exactly where they wanted everything AND how it was wired, they did the ....design thing. It's funny because I showed them my load calks and they cut it in half. They wanted each computer to get a home run, and there are some 20 or so comps. I did talk them into letting me branch a recpt for the pencil shaprener!!! Which reminds me, I need a little assistance on a few items: to start, I need (1) 150W and (3) 75W dimmable transformers. Going in a dirty/dusty area. Any brands you reccommend? The under cab lighting @ 12v. needs to be bright but not hot so no halogens, looking for discrete Xenon(sp?) strips about 3-4 ft. And while I'm on a wild tangent, when cutting FMC do you use the greenlee cutters (with the little saw blade) or do you just snap em and tin snip it? I was working with a guy last week who was razzing me for using the greenlee cutters while he just snaps it over. His method was a little faster, but mine looked cleaner, not that it matters, it's all buried in the walls anyhow |
#4 | ||
Service & Repairs
Trade: Electrician
I try to always use my Roto-splits. The Greenlee named brand are my favorite. Problem is, I don't always carry them around with me in the bucket so I don't always have them nearby. When this happens I use the diagnol cutters (dykes) to split the cable. The problem with doing it that way is the really sharp edges it leaves. Couple that with the non-requirement for using anti-shorts with MC cable and you're looking at a real lousy installation that could very well short circuit within the connector. The good news is that I rarely use MC cable and I WOULD always go and get the splitters. no:
As far as commercial branch circuits go, I do whatever the plan calls for. I wired an animal hospital about a year ago and the most receptacles on any given circuit was two. It made for alot of homeruns. |
#6 | |
For the undercabinet Xenon's, I use Progress's 'Hide-a-Light' Xenon strips. They have a lamp about every 2", so it's very even light. They come in many lengths, and you can butt them end to end to make up something special. You can mount them under most cabinet lips without a light valance, and the fixture will not show.
http://www.progresslighting.com/pdfs/P7505.pdf And here's the transformers I normally use: http://www.progresslighting.com/pdfs/P8653.pdf |
Union Electrician
Trade: Inside Wireman
So the FMC you mention are you talking half inch and larger flex or MC cable?
I don't consider a cable assembly to be conduit, but I haven't seen a greenlee splitter for anything larger than MC. That being said, I always use my MC splitter. For flex I first make a little 'nip' with my dykes on the rib where I want my cut, then snap it and twist it back and forth till it breaks on my cut, then clean it up with my dykes. Doing it that way doesn't seem to 'kink' the flex where you snap it. |
Electrical Contractor
Trade: Electrical
Seatek makes(made) a Rotosplit for 1/2 and I believe 3/4" flex (greenfield).
| Commercial Drywall | northtx | Drywall | 13 | 09-09-2007 10:22 AM |
| Do you own a commercial building/land? | MKamis | General Discussion | 9 | 05-06-2007 09:14 PM |
| New commercial | profinish | Painting & Finish Work | 3 | 02-24-2007 10:44 PM |
| Targeting Commercial Construction | SmithBuilt | Marketing & Sales | 6 | 02-09-2007 10:01 PM |
| HVAC Commercial contract marketing | Erick Wheeler | HVAC | 0 | 08-29-2006 10:58 AM |
