Code Violation?
Hey guys, I've been meaning to ask this for a while. A couple weeks ago I was replacing baseboard and crown moulding at a house, in the one room when I tore the old base off it looks like someone added an outlet down the wall from another one and ran the wire behind the base and then back into and up the wall. Then I found the same thing behind some crown in another room. Is this the work of DIY or is it legal? In the past I have also seen a channel cut in drywall then the wire put in it and mudded over, what about that? Seems a little dangerous to me, but I am no electritian
Dave |
Re: Code Violation?
Well I guess maybe it is a stupid question
any opinions though?Dave |
Trade: electrician Phoenix AZ
Re: Code Violation?
The wire has to be in at least 1 1/4 inches to be legal. In the crown it might be ok. In the base, probably not. When the cut and mud to get around studs/joists it is only legal if the put a metal nail plate covering it.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
Fentoozler
Re: Code Violation?
Could be either....do you think it was fished?
I kind of doubt it...but some guys have made skills with a snake
Re: Code Violation?
Have seen the behind the base trick,
but mostly with 1X8 "mop boards". And with them the box is in the base anyway. Drywall mud? ![]() 8
#6 | |
Re: Code Violation?Quote:
Thanks guys, Celtic, it looked like someone took off the base, cut the drywall and put the wire behind it. I was just curious about it. It looked kinda mickey mouse to me , but I wasn't sure if it was exceptable or not.Dave |
#7 | |
Fentoozler
Many guys will take the "shortcut" route and remove the base/crown to run the NM...then "carefully" nail the base/crown back in place. Is it legal? No Does it happen? Obviously. Is it a crime? Yes...but not a felony
| Did you Know CA Laws on License + Unlicensed Contractors | eagleandbaby | Contractor Licensing | 65 | 03-27-2010 11:44 PM |
| Residential code book | Michaeljp86 | General Discussion | 11 | 12-04-2007 12:14 AM |
| Code Violation for gas line | Bobcat69 | Plumbing | 8 | 03-07-2007 02:13 PM |
| 2 questions - one code, one structural | karma_carpentry | Decks & Fencing | 5 | 09-10-2006 02:55 PM |
