tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
CO, Heavier Or Lighter Than Air
Old 12-30-2006, 07:04 PM   #1
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
By name(1 carbon and 1 oxygen) I would suspect that CO is lighter than air meaning that a ceiling mounted carbon monoxide detector would make better sense and that the ones simply plugged in to the wall at 18" aff would be of no use(in that it would be inhaled before being noticed by the detector).
Or do I have it all wrong? Is CO heavier? or does it completely mix in?
Sparky Joe is offline
Old 12-30-2006, 07:21 PM   #2
mdshunk's Avatar
Rewards Points: 2,002
Re: CO, Heavier Or Lighter Than Air
At sea level and 20*C...
carbon monoxide is 1.145 g/L
ideal air is 1.2 g/L
Carbon monoxide is slightly lighter than air. The difference is so slight that I expect that natural convection currents keep it pretty well mixed.
mdshunk is offline
Old 12-30-2006, 07:29 PM   #3
Union Electrician
Sparky Joe's Avatar
Thanks for the research MD, it's very much appreciated
Or did you know all those numbers off the top of your head
Old 12-30-2006, 07:56 PM   #4
mdshunk's Avatar
I Googled it. Took less that 2 minutes. Quit being so lazy!
mdshunk is offline
Old 12-30-2006, 08:03 PM   #5
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
I have been using the dreaded "I heard from a guy" scientific info on this.
I had always heard that CO was almost neutral so placement of detectors was not critical.
I typically use combo co/smoke detectors where a CO is required.
it's nice to have the facts (looked up for me). Thx Marc.
BTW- Don't you love when folks as about CO2 detectors.
Speedy Petey is offline
Old 12-30-2006, 08:15 PM   #6
Union Electrician
Sparky Joe's Avatar
Hmmm....what would that be....
place a plant in a central location, if it lives CO2 is present, if it dies it's not(or you didn't water it)
Old 12-30-2006, 08:16 PM   #7
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
Just a little co info that I have experienced.
If there is co in your garage in the winter and you leave the door into the house open, the co will take a ride on the cold air and go down into the basement rather than go upstairs.
In the 80's, maybe even now, the code called for some direct fresh air from the outside of a dwelling directly into recirculating forced air system. Often these outside air vents, usually 3 or 4 inch, ended up on the driveway or parking lot side of the dwelling/house /apartment.
Long story short. I tracked the high co readings to 7am to 8am. The people were backed up to the fresh air intake when they were warming up their cars for 15 min or so.
Good example of a situation where not following the code might have been better.
K2 is offline
Old 12-30-2006, 08:26 PM   #8
mdshunk's Avatar
Yeah, everytime you crack open a Pepsi, the darned things go off!
mdshunk is offline
Old 12-30-2006, 09:00 PM   #9
Trade: Electrical
http://www.ilovewavs.com/Effects/Music/RimShot.wav
Old 12-30-2006, 09:05 PM   #10
ABLE1's Avatar
Rewards Points: 922
Here is the install sheet for the Macurco units that I install with alarm panels. Mounting height is listed at 4-5 feet AFF, where people breath.
Attachment 4084
This is line with the specs that MD listed for the weight of CO.
Hope this helps someone.
Les
ABLE1
ABLE1 is offline
Old 12-30-2006, 09:09 PM   #11
mdshunk's Avatar
In fairness, there are CO2 detectors, but they are an HVAC control. They are used in large buildings like supermarkets, retail stores, and theaters. They are used as a predictor of how many people might be occupying the space at the time (more people breathing, more CO2), so that the fresh air dampers can be modulated, and the heat or AC can be predictively brought on early or shut off early so that the setpoint doesn't get overshot due to the increased people load.
mdshunk is offline
Old 12-31-2006, 09:14 AM   #12
Professional Remodeler
firemike's Avatar
Rewards Points: 1,000
An interesting side note - The hemoglobin in the bloodstream accepts carbon monoxide 175 to 200 times easier than it does oxygen, which is why humans are so succeptable to CO poisioning in relativly small amounts over longer periods of time (even at COHb levels of 10% or less)
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 12-31-2006, 04:19 PM   #13
acrwc10's Avatar
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Rewards Points: 150
I got a does of co exposure in high school auto shop. I did not feel it I stood up walked outside hit my head on the window frame and knocked myself out . There is also a Darwinian type of wake surfing on ski boats called "teaking" where a person wears no life vest and they body surf the wake behind the boats swim platform. CO builds up in this spot and they can pass out and drown and or surf under the boat into the prop. Not that this has anything to do with co detectors ,but I thought it might be interesting to hear.
acrwc10 is offline
Old 12-31-2006, 04:46 PM   #14
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
It doesn't have to be perfect, it's just a closet!
ron schenker is offline
Old 12-31-2006, 05:13 PM   #15
Union Electrician
Sparky Joe's Avatar
If I weren't so lazy then we wouldn't get the chance to innadvertantly share knowledge in a place where everyone is going to read. Isn't that the whole idea of a forum?
Oh and I have to point out that some of our greatest inventions were due to being lazy, like the wheel, or the remote control
Old 12-31-2006, 05:17 PM   #16
mdshunk's Avatar
Yes. Thanks. This forum depends on a certain amount of lazy people, and a certain amount of people to Google an answer for them. Otherwise, it would get boring some days. I certainly don't mind. Just ribbing you a little.
mdshunk is offline
Old 12-31-2006, 06:57 PM   #17
Union Electrician
Sparky Joe's Avatar
I know, I know,
I just like to mess with those who can take it too.
lighter nailers for sheathing,subfloors and roof OntarioFramer Tools & Equipment 4 04-30-2006 12:17 PM
