Circuits Breaking
Old 09-19-2007, 07:34 PM   #1
barbie13607's Avatar
Trade: stained concrete, painting, tile
Circuits Breaking
circuits breaking
I know nothing about electrical so I'm hoping someone can help me here. a friend of mine in a wheelchair is renting a new apartment. The circuit breaker keeps flipping off. She has to call someone to come flip it on - usually me.
The landlord blames new codes that are so strict they flip off when a light bulb burns out. I know the breaker flips off when a bulb burns out because I was there once when it happened.
She can't have more than three things going in a room - TV, cable box, overhead light - if she tries to get on her computer - poof, gone.
Her brother said it is probably wired with copper. Would this make a difference?
thanks
barbie13607 is offline
Old 09-19-2007, 07:42 PM   #2
mdshunk's Avatar
Re: Circuits Breaking
The landlord is a moron, and copper has nothing to do with it.
When you rent, you have little recourse other than to move. What you describe doesn't seem like a hazard, but darned inconvenient.
mdshunk is offline
Old 09-19-2007, 08:44 PM   #3
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Does it always trip when ONE certain thing is turned on, or just when more than a couple of things are on at once?
Is this a new apartment, as in just wired/rewired, or just new to your friend?
Unfortunately, I'm doubtful this landlord will fix it anyway, judging by what he's already said.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 09-19-2007, 09:01 PM   #4
Newly built apartments.
My friend has a two year lease so she has to have good cause to move. She's on disability and in a wheelchair. It was hard for her to find a handicap apartment - now this.
The circuits go off at various locations in the place when a bulb burns out, when there is a "surge" like the microwave. It isn't just one room or appliance that sets it off but only the electric to that room goes off - not all the electric.
thanks for any replies.
Old 09-19-2007, 09:03 PM   #5
Super B
skyhook's Avatar
Recently had a ceiling fan / light combo that would blow the glass off the bulbs. The tenant never mentioned it. They moved out and when I put new bulbs in, they smoked and blew the glass off. I checked the connections in the switch box. Sure enough the neutral was loose. I reconnected the neutral and haven't had a problem since.
skyhook is offline
Old 09-19-2007, 09:06 PM   #6
JohnJ0906's Avatar
Trade: Electrician
The landlord needs an electrician to look at this.
He might even still be under warranty.
John from Baltimore
"One Day at a Time"
Old 09-19-2007, 10:31 PM   #7
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
I have to say I've never seen a lightbulb explode. But I never have seen one fed with 240 volts
Sparky Joe is offline
Old 09-19-2007, 10:55 PM   #8
Fentoozler
Celtic's Avatar
They get real bright...but only for a second.
Celtic is offline
Old 09-20-2007, 03:12 AM   #9
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
AFCI's ..........
Speedy Petey is offline
Old 09-20-2007, 11:14 AM   #10
gregj's Avatar
Your friend should call the landlord to flip the breaker back on every single time it happens. Otherwise the landlord won't fully understand how inconvenient it is. Since this was rented as a handicap accessible apartment I would think that it is the landlords responsibility to turn the breaker back on if it's not accessible to the tenant.
Your friend should also document each time the breaker trips, what was running and how long it took before the landlord got the power back on. That will provide the documentation needed to justify breaking the lease if the issue isn't resolved.
I'm not a sparky but it does indeed sound like AFCI issues. This could be related to an actual potentially hazardous wiring issue or an overly sensitive AFCI. I've heard that the earlier AFCIs were very prone to false tripping. Perhaps the more recently manufactured ones are better? Maybe the sparkies on this site can chime in on whether she should try to convince the landlord to have the AFCI breaker replaced with a newer one.
gregj is offline
Old 09-20-2007, 11:31 AM   #11
Super B
skyhook's Avatar
First time here too. Maybe that's why they are so bright. Actually I tested it first.
skyhook is offline
Old 09-20-2007, 03:27 PM   #12
Union Electrician
Sparky Joe's Avatar
Very good idea
Breaking Down T&M in Estimates dirt diggler Business 9 09-13-2006 01:01 PM
Electrical Box removing and disconnecting circuits MikeT Electrical 9 08-15-2006 06:07 AM
Standard way to wire lighting circuits robertc65 Electrical 9 03-08-2006 02:18 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Using 12/3 to power Two Circuits robertc65 Electrical 18 02-16-2006 12:26 AM
