tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Chicago Codes Are Made By Unions
Old 11-24-2017, 05:57 AM   #1
I41Lovemyjob's Avatar
When will this City catch up with the times and make our life easier. For example No Romex? Really? You would think Pex is a four letter word and I'm pretty sure the new requirements for balconies will ensure after the next natural disaster you'll find cockroaches perched on a Chicago balcony preparing a class on pyramids for the next pack of of rats that come along.
I41Lovemyjob is offline
Old 11-24-2017, 07:39 AM   #2
hdavis's Avatar
Rewards Points: 3,449
Re: Chicago Codes Are Made By Unions
I didn't realize Chicago is so backward.
hdavis is offline
Old 11-24-2017, 08:47 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 9,900
Nice first post.
My guess is you're here just for a one-post bitch session.
Chuck Norris can start a fire by rubbing two ice cubes together.
480sparky is online now
Old 11-24-2017, 08:55 AM   #4
B.Johnson's Avatar
Trade: Builder
Rewards Points: 466
I'm not sure his user name is appropriate for the post.
Home Designer Series Software
B.Johnson is offline
Old 11-24-2017, 09:22 AM   #5
tjbnwi's Avatar
Rewards Points: 1,036
FYI-Chicago has adopted the NEC-it goes into affect in about 3 months.
The "new" balcony requirements are about 10 years old now...
tjbnwi is offline
Californiadecks (11-24-2017)
Old 11-24-2017, 12:32 PM   #6
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,363
They will never catch up,its by design
WBailey1041 is offline
Old 11-24-2017, 06:13 PM   #7
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,155
Maybe Itís supposed to be ironic.
Big Johnson is offline
Old 11-24-2017, 07:43 PM   #8
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,092
You do realize how many balconies have collapsed in Chicago killing numerous people because of shoddy construction?
A lot of Chicago codes are very old.
And The codes for balcony construction has nothing to do with the union it has to do with the fact that balconies were collapsing that were literally ripping away from the wall, so yea they are pretty strict with balconies Especially when youíre tying a new balcony into an old building....not smart to tapcon wood into a 90 year old common brick wall
Windycity is offline
Old 11-24-2017, 07:59 PM   #9
slowsol's Avatar
Rewards Points: 2,192
Someone should be along shortly to explain that you canít use nm cable because of the mutant rats.
-John
slowsol is offline
Old 11-24-2017, 08:42 PM   #10
tjbnwi's Avatar
This is the collapse that triggered the balcony/porch/deck code change.
https://en.wikipedia.org/wiki/2003_C...lcony_collapse
tjbnwi is offline
SmallTownGuy (11-25-2017)
Old 11-24-2017, 09:09 PM   #11
GC/carpenter
Californiadecks's Avatar
Rewards Points: 2,638
Actually not according to the article. It may have triggered it, but it wasn't the cause of the collapse.
The deck wasn't even to existing code. So there was no code problem there was a contractor problem.
The balcony also had inadequate supports,[5] was floored with undersized lengths of wood, and was attached to the walls with screws that were too short.[1] However, the City of Chicago's Inspectional Services Department visited this site over 5 times and never noticed or cited the code violations noted above.
Mike.
_______________
Californiadecks is offline
Old 11-24-2017, 09:15 PM   #12
tjbnwi's Avatar
Mike.
_______________
I don't understand your statement.
My statement did not infer or reference the porch that collapsed was built to any code. Just that it's collapse caused the extreme code to be put in place.
According to the quote you included, looks like an inspector problem also...
tjbnwi is offline
Old 11-24-2017, 09:18 PM   #13
GC/carpenter
Did the inspector build the deck? ****ty work is never an inspector problem where I come from.
Mike.
_______________
The Following User Says Thank You to Californiadecks For This Useful Post:
NJGC (11-25-2017)
Old 11-24-2017, 09:18 PM   #14
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,624
I'm pretty sure that most of the collapses were not built to code or maintained properly.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
The Following User Says Thank You to TNTSERVICES For This Useful Post:
Old 11-24-2017, 09:19 PM   #15
Hair Splitter
Trade: General
Originally Posted by 480sparky View Post
Nice first post.
Doesn't make it any less true.
Old 11-24-2017, 09:21 PM   #16
tjbnwi's Avatar
Mike.
_______________
Agree, this building was being inspected during a remodel (finished about a year before the collapse). It is their job to note code violations and require they be corrected.
tjbnwi is offline
Old 11-24-2017, 09:23 PM   #17
GC/carpenter
Exactly. There's many old decks that are not in any danger of collapsing if built right. The number one reason for deck failure is improper flashing. No code in the world will protect a wood structure if it isn't protected properly.
Also I might add that collapse in Chicago had too short of screws. Easily missed by an inspector. That didn't make the collapse his fault.
Mike.
_______________
TNTSERVICES (11-25-2017)
Old 11-24-2017, 09:27 PM   #18
tjbnwi's Avatar
Mike.
_______________
Is it the inspectors fault they missed the undersized joists and supports? I know those are visible on this open porch.
tjbnwi is offline
Old 11-24-2017, 09:45 PM   #19
GC/carpenter
****ty building not built to code is the builders fault always.
Every single one of my plans have a disclaimer when stamped. Says right on it, (paraphrased) contractor is responsible to build everything to code.
Not to mention, every city in America has an immunity clause for city employees.
Mike.
_______________
Old 11-24-2017, 09:49 PM   #20
GC/carpenter
Also There's no such thing as typical, when it comes to building out here anyway. Joists that are fine in one place may not be in another. Inspectors come to inspect something else and don't go back and research an address to find out what was engineered, or approved by the plan checker. So just because he didn't do that for the whole house, in no way makes it his fault.
Mike.
_______________
Residential Building Codes nwksremodeler Contractor Licensing 15 02-03-2014 09:47 AM
Porter Cable Millworker Tools & Equipment 55 11-01-2013 06:42 PM
unions oldrivers Off Topic (Non Trade) 2 03-19-2011 06:07 PM
