tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Cant Find A Photocell That Works On A Dimmer Circuit
Old 02-27-2018, 05:23 AM   #21
Rmcooke86's Avatar
Trade: Electrician / control tech
Re: Cant Find A Photocell That Works On A Dimmer Circuit
Originally Posted by 3bar View Post
Originally Posted by 480sparky View Post
Those look like the most ordinary, plain-jane everyday PCs you see by the millions. Even the grocery stores and pharmacies carry them.
V
why should they look different? its what's inside that matters. they operate different.
Just get everything rated for your legs, ie your cell dimmer and try it. A better alternative that will 100 percent work would be a time clock, just set your appropriate times depending the season. You can easily turn your switch into a two gang box and install it directly next to it.
Rmcooke86 is offline
Old 02-27-2018, 08:03 AM   #22
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
A timer would be a pain to me. Every day the light changes.
i think i found the solution. basicaly i cant use a thermal photo sensor, which is what's most commonly used. i need an electronic photo sensor.
What is a thermal photo sensor? How would it work in freezing weather. Photo cells are photo-electric and triggered by light waves. Maybe they have some combo units for some specialty, I don't know.
RangoWA is offline
Old 02-27-2018, 05:36 PM   #23
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,047
Don't know about current tech, but back in the day it used a photoresistor that let more or less current flow depending on the light level. That current would heat up a bimetallic strip, which then flexed to bring a pair of electrical contacts together (or apart).
These days, most stuff is all solid state unless it's switching some pretty hefty loads.
Tinstaafl is offline
Old 02-27-2018, 09:48 PM   #24
3bar's Avatar
Trade: carpenter
Rewards Points: 466
most are not solid state. the old thermal resistors is what you'll find in most stores. i guess its just proven old technology. but it doesnt work well with led lights and dimmers.
3bar is offline
Old 02-28-2018, 07:13 AM   #25
RangoWA's Avatar
Trade: General
I never heard them called thermal before. How do they work in the winter. I thought they were sensitive to photons.
RangoWA is offline
Old 02-28-2018, 08:36 AM   #26
Capra aegagrus
Tinstaafl's Avatar
Pretty well.
It does seem counterintuitive. I never looked into it, but I imagine the bimetallic assembly would be fashioned in such a way that its range of motion with/without current well exceeds that provided by normal changes in ambient temps.
Old 05-21-2018, 09:04 AM   #27
BurchSung's Avatar
Trade: Tools
Rewards Points: 2
Hi..i am a new user here. As per my knowledge dimming them will can't give you the warm light you want. Mine are 350 lumens 2200k at 4.5 watts each. If you are wanting a brighter light on occasion you might want to install a led spot light. But that's getting into some wiring.
BurchSung is offline
Circuit out after kitchen remodel, undercab lights, in over my head. Please help! RDBD Electrical 25 02-23-2015 10:14 PM
Overloaded Circuit and Wiring Advice Rangers Electrical 20 01-14-2013 07:42 PM
Want to find a good talented designer and or architect. Greg from K/W Architecture & Design 22 08-12-2012 10:45 PM
Test - How many terrible practices can you find ??? theflynner Roofing 20 05-27-2012 09:03 AM
Drawing Symbol and Color for Different Construction Works and Items nicolas Masonry 5 02-05-2008 03:37 AM
