Cant Find A Photocell That Works On A Dimmer Circuit - Electrical - Contractor Talk
Old 02-18-2018, 01:04 AM   #1
3bar's Avatar
Trade: carpenter
Rewards Points: 476
every photocell i've seen says not to be used on a dimmer circuit.
anybody know of one that will work?
3bar is offline
Old 02-18-2018, 12:40 PM   #2
Rmcooke86's Avatar
Trade: Electrician / control tech
Re: Cant Find A Photocell That Works On A Dimmer Circuit
As long as you have the dimmer installed after the photo cell I don't see a issue. Where is this being installed?
Rmcooke86 is offline
Old 02-19-2018, 03:30 AM   #3
3bar's Avatar
Trade: carpenter
Rewards Points: 476
thats what i thought. but after reading how photocells work, that doesnt seem to be the case.
i have dimmer on exterior lights and want to add a photocell.
3bar is offline
Old 02-19-2018, 08:13 AM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,728
Use an astrological clock timer.
Inner10 is online now
TNTSERVICES (02-23-2018)
Old 02-19-2018, 08:24 AM   #5
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
If you can't find one you could have the photocell operate a relay that completes the lighting circuit.
RangoWA is offline
Old 02-20-2018, 06:15 AM   #6
Rmcooke86's Avatar
Try installing the dimmer on the load side of the photo eye (red wire). Take a look at my rough drawings for both applications of what will and won't work.
When learning electrical it takes time, experience and simple trying. Good luck.
cant find a photocell that works on a dimmer circuit-1519124918497833572951_1519124976278.jpg   cant find a photocell that works on a dimmer circuit-1519125218154784494335_1519125231204.jpg
Old 02-20-2018, 08:58 AM   #7
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,898
Why the need for a dimmer? What kind of lamps are you wanting dimmed and why do they need to be on a photocell?
Due to circumstances beyond my control, I am here.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Old 02-20-2018, 09:15 AM   #8
RangoWA's Avatar
Trade: General
I recently put my outside lights on a photocell. Finally they made some LEDs I could live with so leave the switch on now and it lights up my driveway with a warm color. My truck is parked right there loaded with tools. It has an alarm but I don't want a window broken by some crackhead.
RangoWA is offline
Old 02-22-2018, 01:11 AM   #9
3bar's Avatar
Trade: carpenter
Rewards Points: 476
obviously the dimmer would be after the photocell, but most photocells are thermal it appears. i'd need one with a relay inside. if its thermal, and with a dimmer, the resistance will be too low to heat up the thermal element in the photocell, and the lights will never turn off.
i have can lights all around exterior of house, and i recently changed them to led halogen style par30 bullbs. they are really bright, and no they are not available in lower watts. i dim them way down for a nice soft light.
3bar is offline
Old 02-22-2018, 09:51 AM   #10
480sparky's Avatar
Get lower-wattage LEDs.
BTW, there is no such thing as LED halogens. They're either LED or halogen.
Old 02-22-2018, 12:13 PM   #11
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 92
Good luck.
There are several other threads online saying it just won't work, and why. Sorry I did not save the links, but that's what I came up with trying to answer the original question.
P42003 is offline
Old 02-23-2018, 12:30 AM   #12
3bar's Avatar
Trade: carpenter
Rewards Points: 476
thats why i said "halogen style" these new sylvania ultra led par30 actually look like the old halogen bulbs, and the light output is the same too. real nice bulbs. 75w output while only using 13w.
3bar is offline
Old 02-23-2018, 07:10 AM   #13
RangoWA's Avatar
Trade: General
I don't think dimming them will give you the warm light you want. Mine are 350 lumens 2200k at 4.5 watts each. Nice warm color to me.
If you are wanting a brighter light on occasion you might want to install a led spot light. But that's getting into some wiring.
RangoWA is offline
Old 02-23-2018, 07:33 AM   #14
Inner10's Avatar
Run the photocell into a relay switching the power to a dimmer.
Or just use a dimmer timer set to sunrise/sunset...like I said...
Old 02-23-2018, 08:36 AM   #15
480sparky's Avatar
2200K? Egads.... that's a yellow 'bug' light!
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
Tinstaafl (02-23-2018), TNTSERVICES (02-23-2018)
Old 02-23-2018, 11:27 AM   #16
RangoWA's Avatar
Trade: General
It's a nice warm orange. And I do know my colors. Makes the house look great at night. I can't say it's labeled accurately though.
RangoWA is offline
Old 02-25-2018, 11:14 PM   #17
3bar's Avatar
Trade: carpenter
Rewards Points: 476
i think i found the solution. basicaly i cant use a thermal photo sensor, which is what's most commonly used. i need an electronic photo sensor.
like this
Intermatic EK4336S
https://www.amazon.com/Intermatic-EK.../dp/B0119Q6QRY
or Intermatic EK4436SM
https://www.amazon.com/Intermatic-EK.../dp/B01IXUYB9E
3bar is offline
Old 02-25-2018, 11:22 PM   #18
3bar's Avatar
Trade: carpenter
Rewards Points: 476
3bar is offline
Old 02-26-2018, 06:17 PM   #19
480sparky's Avatar
Those look like the most ordinary, plain-jane everyday PCs you see by the millions. Even the grocery stores and pharmacies carry them.
Old 02-27-2018, 03:09 AM   #20
3bar's Avatar
Trade: carpenter
Rewards Points: 476
why should they look different? its what's inside that matters. they operate different.
3bar is offline
Circuit out after kitchen remodel, undercab lights, in over my head. Please help! RDBD Electrical 25 02-23-2015 11:14 PM
Overloaded Circuit and Wiring Advice Rangers Electrical 20 01-14-2013 08:42 PM
Want to find a good talented designer and or architect. Greg from K/W Architecture & Design 22 08-12-2012 10:45 PM
Test - How many terrible practices can you find ??? theflynner Roofing 20 05-27-2012 09:03 AM
Drawing Symbol and Color for Different Construction Works and Items nicolas Masonry 5 02-05-2008 04:37 AM
