tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Can You Convert Glass Fuses To Circuit Breakers
Old 06-20-2010, 04:09 PM   #1
tonytnt's Avatar
Trade: Windows, Siding, Gutters
Can a 60 amp service with old glass fuses be changed to circuit breakers, without updating the electric service? My uncle is in his 70's and does not want to spend the money to upgrade his electrical service. He has a box with 4 glass fuses. Can they be replaced with 4 circuit breakers?
tonytnt is offline
Old 06-20-2010, 04:42 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,098
Re: Can You Convert Glass Fuses To Circuit Breakers
Local jurisdiction's call.
Chuck Norris can cut through a knife with hot butter.
480sparky is online now
Old 06-20-2010, 05:05 PM   #3
erikm's Avatar
Trade: HVAC
Rewards Points: 75
Sounds like an old 2 wire(fuzzy wire)set up!no ground.
Most likely it would be an up grade job and rewire to current codes
erikm is offline
Old 06-21-2010, 08:57 AM   #4
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Tell him to swat away the dust from his wallet, just because it has worked OK for 60+ yrs does not mean it is safe any more. It is time to upgrade.
woodchuck2 is offline
Old 06-21-2010, 09:06 AM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,658
Inner10 is offline
Old 06-21-2010, 11:28 AM   #6
stars13bars2's Avatar
Rewards Points: 75
Check to make sure that the fuses are not oversized at the present time. This is one of the biggest hazzards that is found with these four circuit panels. If it is found that the fuses are oversized, do whatever is necessary to prevent this from happening again. Replace with s type fuse adaptors of the proper size, or change the panel out. 20 amp fuses are not allowed on #14 copper wire!!!!! 30 amp fuses should probably not be in the panel at all. Uncles are supposed to be cremated only posthumously.
stars13bars2 is offline
Old 07-07-2010, 05:20 PM   #7
Master Electrician
pesdfw's Avatar
Trade: Electrician
At some point every service needs to be replaced. Those fuses are a sure sign of needing it. Very outdated.
pesdfw is offline
Old 07-07-2010, 08:02 PM   #8
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Hmmmmmm.
Just because it has worked for 60+ Years WITHOUT an Injury or Fire, makes it "Unsafe" today.....
Just sayin'!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 07-07-2010, 08:28 PM   #9
mrmike's Avatar
Trade: Electrical & Carpentry
You need to have your electrical meter pulled to have the power off to change them out,, so usually you have to call your power company & they will ask if it is for any upgrade or a repair,etc. . So no, you cannnot just replace them with breakers without an upgrade and and without an electrical inspection.............
mrmike is offline
Old 07-07-2010, 08:43 PM   #10
rselectric1's Avatar
Rewards Points: 562
We can break the seal and pull the meter ourselves in Illinois. (I'm guessing in most other places that's the case too)
I was checking the size of feeders on a service for a job of Angus' a couple months ago and after I pulled off the panel, the meter fell off in my hands leaving Angus and the HO in the dark! OOPS
You're right though MrMike. Not a diy proposition. Too many variables to list.
rselectric1 is offline
Old 07-07-2010, 08:58 PM   #11
Originally Posted by MALCO.New.York View Post
Hmmmmmm.
Just sayin'!
And for all of those 60 years
it has been getting more, and more,
and more......
overloaded.
Just sayin'
neolitic is offline
Old 07-07-2010, 09:13 PM   #12
Handle It!
and more......
overloaded.
Just sayin'
Just sayin'......
(But you KNOW I LOVE to play "The Devils Advocate"!)
The Following User Says Thank You to MALCO.New.York For This Useful Post:
neolitic (07-07-2010)
Old 07-07-2010, 09:51 PM   #13
Head Grunt
woodchuck2's Avatar
Hmmmmmm.
Just sayin'!
I understand your point Malco, i am assuming unsafe due to additional load throughout the years of use and the condition of the service wire after this many years of exposure to the elements.
Old 07-07-2010, 09:58 PM   #14
Rewards Points: 562
Actually I think he was referring to Neo's age, which is somewhere between 40 and 100.
Old 07-07-2010, 10:04 PM   #15
480sparky's Avatar
At 60 years, the insulation on the wiring has probably reached EOL.
Old 07-07-2010, 10:36 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,140
OTOH, every few weeks I run into some good old K&T wiring that's still sailing along quite comfortably.
Until I run into it.
Tinstaafl is offline
Old 07-07-2010, 11:32 PM   #17
Handle It!
The most interesting factor is.......
Appliances and Devices require MUCH less e- to operate these days.
Yet we have more toys that plug in.....
Old 07-08-2010, 04:11 AM   #18
480sparky's Avatar
Why are you driving your truck into people's houses?
Old 07-11-2010, 06:06 PM   #19
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
Why not just disconnect at the service head?
Magnettica is offline
all 30 amp fuses from the inside handyman99 Electrical 11 09-05-2009 09:49 PM
1 circuit 2 breakers CER Electrical 25 04-26-2009 02:34 PM
Frameless glass shower build, ideas please rotarex General Discussion 23 12-29-2008 09:57 AM
Siemens circuit breakers Krashk2 Electrical 3 09-28-2007 04:16 PM
changing fuses to circuit breakers 747 Electrical 11 07-27-2005 01:10 PM
