tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Can A Dishwasher And A Garbage Disposal Share A Neutral?
Old 09-20-2017, 10:00 PM   #41
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,362
Re: Can A Dishwasher And A Garbage Disposal Share A Neutral?
Originally Posted by 480sparky View Post
Nope. I didn't make any claims. So it's not up to me to prove anything.
Yes you did.
you gonna challenge - YOU provide the evidence.
Oh wait - you misplaced your code book - my bad.
Net Zero Energy Is Here Now
“The worst day working for yourself, is still better than the best day working for someone else!”
..Jim Rohn
SmallTownGuy is online now
Old 09-23-2017, 01:10 AM   #42
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,425
See - 210.21 Outlet Devices.
- - (B) Receptacles.
- - - (3) Receptacle Ratings. Where connected to a branch circuit supplying two or more receptacles or outlets, receptacle ratings shall conform to the values listed in Table 210.21(B)(3), or where larger than 50 amperes, the receptacle rating shall not be less than the branch-circuit rating.
- - - - Table 210.21(B)(3) Receptacle Ratings for Various Size Circuits (Jerry's note: This states 15 amp receptacle on a 15 amp circuit or a 15 amp receptacle on a 20 amp circuit, *but not* a 20 amp receptacle on a 15 amp circuit.)
[URL="https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja &uact=8&ved=0ahUKEwix-MTJxLrWAhVs5oMKHYHiB3EQjRwIBw&url=https%3A%2F%2Fdi y.stackexchange.com%2Fquestions%2F25421%2Fwhy-is-it-ok-to-use-a-50-a-receptacle-on-a-40-a-circuit&psig=AFQjCNHh7sPfrbqFBeYOH71EVADFLJ0MDA&us t=1506229570736291"]
That is supposed to be a link to an image of the table of permitted ratings v CB amps.
And to think I was confused about pass through vs. face plate ampacity......
Fouthgeneration is offline
Old 09-24-2017, 07:11 AM   #43
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 514
I agree with 4th gen--- Table 210.21(B)(3) is clear that a 15 amp circuit cannot be connected to a 20 amp circuit.
I also would not recommend a multiwire branch circuit anymore in a residence with afci requirements and now with gfci requirements for dishwashers.
If you run a multiwire branch circuit for a disposal and dishwasher you would have to install a gfci in a readily accessible location for the dishwasher.
C'est Moi is offline
Old 09-24-2017, 07:18 AM   #44
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 514
Originally Posted by Leo G View Post
They made a code that you can't put a panel box within 3 feet of a window because some stupid person reached in a window and killed himself off because he reached into the open panel.
That's a stupid code.
I assume that is a local code because it is not an NEC code
Old 09-24-2017, 12:45 PM   #45
Trade: Masonry
Not installing separate circuits and dedicated outlet fixtures, (every duplex outlet providing an outlet for low Ampere low use appliances)
is silly. As inverters and variable frequency digital drives become evermore common and "pollute" the their circuits with harmful voltage spikes/noise.
The code is a GUIDE for MINIMUM qualities and amounts, any structure that isn't a flop house or pre- engineered metal building should exceed them in a rational market place. IMHO
Yugos were legal, but would you let your only daughter drive/own one?
Old 09-24-2017, 01:00 PM   #46
tjbnwi's Avatar
Rewards Points: 1,194
The manufacturers installation instructions are the guiding documents. The NEC states you have to install per manufactures instructions. Most "permanently" installed require a separate circuit.
On the Yugo question--sure why not. By now I would have taken care of any issues.
tjbnwi is online now
Fouthgeneration (09-24-2017)
Old 09-24-2017, 04:54 PM   #47
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 514
Some appliance mfg. recommend a separate circuit so that does not require a separate circuit. I do agree that most of them do state separate circuit.
Old 09-24-2017, 06:12 PM   #48
tjbnwi's Avatar
I'm having a hard time understanding your response.
Separate circuit or not if the manufacture installation documents state separate circuit?
Old 09-24-2017, 07:10 PM   #49
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 514
I am saying that if the mfg company recommends a separate cirxuit then that is not the same as the mfg company requiring a separate circuit.
One is a requirement and the other is a recommendation and as such we do not have to follow it.
Old 09-24-2017, 08:35 PM   #50
tjbnwi's Avatar
Okay. Don't recall ever seeing one that "recommended" a separate circuit. If they mention it at all it's been in the "electrical requirement" section.
I will pay closer attention on the next few installs.
Old 09-24-2017, 09:40 PM   #51
Irishslave's Avatar
Rewards Points: 1,532
Anyways job was completed last week 5 devices (outlets) 4 home runs other than pulling the 200+ foot of NMB.....piece of cake.....no garbage grinder...no DW....homeowner wanted neither
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is online now
Old 09-24-2017, 10:15 PM   #52
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 2,684
I don't have either of those. My dishwasher cleans the house, cooks me dinner, makes my lunch and does the laundry.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-25-2017, 08:28 AM   #53
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,272
I thought she only packed you lunch on Fridays?
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 09-25-2017, 08:45 AM   #54
LRG WoodCrafting
Leo G's Avatar
Friday is Tuna day. Thursday is chicken salad day. Mon-Wed is deli day.
She loves me all week.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 10-22-2017, 12:30 AM   #55
Hotneutral's Avatar
Trade: Electrical
Rewards Points: 8
Appliances that consume half the ampacity of the circuit must be dedicated. If a diswasher uses 10.01 amps on a 20 amp circuit it must be a dedicated circuit. Likewise with disposals. Most are close enough to warrant wiring a dedicated circuit. Allowance for future appliance upgrade should be considered as well. I?ve never heard about the window rule for panels but considering the fact that most windows have a sill if the pane is three feet away then the sill is less which violates nec requiring panels to have 3 feet of clearance at minimum. More in some cases. I?m in the US so Canadian, European, etc. codes may vary on this I do not know.
Hotneutral is offline
The Following User Says Thank You to Hotneutral For This Useful Post:
Fouthgeneration (12-20-2017)
New Sink And Now Disposal Too Low sliver Plumbing 6 03-31-2017 11:48 AM
Giveaway! Enter To Win Kenmore Built-In Dishwasher! Cricket General Discussion 61 04-12-2016 06:15 PM
dishwasher / disposal outlet - Old work box extension dcapone Electrical 10 10-17-2013 08:46 PM
Tiled In Dishwasher Kowboy General Discussion 2 01-20-2013 01:20 AM
2 dishwasher hookup, one drain CGallagher Plumbing 7 03-24-2011 06:25 PM
