tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Can A Dishwasher And A Garbage Disposal Share A Neutral?
Old 09-13-2017, 10:18 PM   #1
Irishslave's Avatar
Rewards Points: 2,606
I was thinking running 14-3....both sides dedicated....yeah yeah I know opposite sides of the bus or you will potentially fry the neutral
But aint this how it is usually done? You already need so much wiring for the kitchen this saves space and wire
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is online now
Old 09-13-2017, 10:46 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,068
Re: Can A Dishwasher And A Garbage Disposal Share A Neutral?
Ignoring the manufacturer's recommendation for dedicated circuits, I'd run 20A 12/3.
Tinstaafl is online now
Fouthgeneration (09-20-2017)
Old 09-13-2017, 10:55 PM   #3
Irishslave's Avatar
And you would what? Integrate recepticles on those (2) 20 amp circuits? Maybe tag one each for a light too?
I'm trying to come up with a Kitchen plan that makes sense w/o overkill.
NEC says at least (2) 20 amp circuits for a kitchen...plus a dedicated for the micro and frig
Old 09-13-2017, 10:59 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,046
The two 20a kitchen circuits (SABC's) cannot be used for either the dishwasher or the garbage grinder.
My SOP is to install a 20a circuit for both.
And yes, they can be wired a 12/3, with a common disconnect, and share a neutral.
Chuck Norris can cut through a knife with hot butter.
480sparky is online now
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
Seven-Delta-FortyOne (09-13-2017), TNTSERVICES (09-20-2017)
Old 09-13-2017, 11:06 PM   #5
Irishslave's Avatar
Wouldn't a common disconnect put both circuits on one bus? Geez I'm up to 6 circuits w/o lights
Old 09-13-2017, 11:14 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Skimping on wire usage is a disservice to your client on more than one front, leaving aside any code issues. The responsible thing to do is not to wire to the absolute minimum requirement.
And with an eye to the future, I suspect that just about any shared-neutral circuits are going to be a problem down the road.
Old 09-13-2017, 11:25 PM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,860
No.
And it's required by code.
Delta
I have an Edifice Complex.
Old 09-14-2017, 12:24 AM   #8
Irishslave's Avatar
so now all MWBC's have to be on double pole breakers to comply?
Old 09-14-2017, 08:16 AM   #9
480sparky's Avatar
Take a good look how buses in most panels are arranged.
Old 09-14-2017, 08:23 AM   #10
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 540
Here, we are required to put all 120v 15 and 20 amp kitchen outlets on AFCI, not just counter top. May be easier to find single pole afci instead of 2 pole. If that is the case, you couldn't share neutral.
TxElectrician is online now
Old 09-14-2017, 10:58 AM   #11
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 4,254
Around here the DW and disposal need to be on a single 2 pole breaker. So yes, they share a neutral. Personally I think it's stupid. It puts 220v in that box.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-14-2017, 11:07 AM   #12
480sparky's Avatar
There's 220 in your electric stove. There's 220 in your electric water heater. There's 220 in your well pump. There's 220 in your bubble tub. There's 220 in your welder. There's 220 in your air conditioner compressor. And there's 220 in your ENTIRE PANEL! Oh, the horrors!
The Following User Says Thank You to 480sparky For This Useful Post:
Old 09-14-2017, 11:11 AM   #13
Trade: Electrical
Rewards Points: 540
I've got 221
The Following 3 Users Say Thank You to TxElectrician For This Useful Post:
Golden view (09-14-2017), overanalyze (09-14-2017), rselectric1 (09-15-2017)
Old 09-14-2017, 11:13 AM   #14
LRG WoodCrafting
Leo G's Avatar
Yes I totally understand that. But you expect it to be there. It's a 220 volt outlet so you expect 220v to be there. This is two 120v outlets with the capacity for you to get 220v out of it.
If you take wire and plug it into each outlets hot you get 220v. You don't get that with an ordinary outlet.
All this is to save 1 wire.
You are thinking like an electrician, not the normal moronic home owner.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-14-2017, 11:15 AM   #15
Trade: Electrical
Rewards Points: 540
That's why moronic HOs should call simeone qualified
The Following User Says Thank You to TxElectrician For This Useful Post:
AustinDB (09-18-2017)
Old 09-14-2017, 11:20 AM   #16
LRG WoodCrafting
Leo G's Avatar
Of all the codes I've seen written I've seen some pretty stupid ones because 1 person got themselves killed because they were a stupid HO. Yet a new code was written.
This is one of those codes that should have never been written.
They made a code that you can't put a panel box within 3 feet of a window because some stupid person reached in a window and killed himself off because he reached into the open panel.
That's a stupid code.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-14-2017, 02:48 PM   #17
480sparky's Avatar
Being an electrician, I expect just about ANY box can have 220 in it. Or 208. Or 480.
If said 'normal moronic home owner' gets zapped because they're a normal moron, oh well. They're free to kill themselves with their own stupidity. No law against that.
Old 09-14-2017, 03:27 PM   #18
LRG WoodCrafting
Leo G's Avatar
The codes aren't for the safety of electricians.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-14-2017, 06:03 PM   #19
ComRemodel's Avatar
Trade: electrical
Rewards Points: 130
Obviously, since people seem to be getting dumber and dumber every code cycle has more and more ridiculous requirements to keep them alive. I say let Darwin do his thing.
-Hal
ComRemodel is offline
Old 09-14-2017, 08:06 PM   #20
480sparky's Avatar
-Hal
Agreed.
If Darwin was right, how come there's still so many stupid people?
New Sink And Now Disposal Too Low sliver Plumbing 6 03-31-2017 11:48 AM
Giveaway! Enter To Win Kenmore Built-In Dishwasher! Cricket General Discussion 61 04-12-2016 06:15 PM
dishwasher / disposal outlet - Old work box extension dcapone Electrical 10 10-17-2013 08:46 PM
Tiled In Dishwasher Kowboy General Discussion 2 01-20-2013 01:20 AM
2 dishwasher hookup, one drain CGallagher Plumbing 7 03-24-2011 06:25 PM
