Burnt G F I
Old 04-29-2006, 07:04 PM   #1
ALL VINYL
all vinyl's Avatar
Trade: VINYL SIDING CARPENTRY
Question
Burnt G F I
I have never seen this befor and ddon't want to again . I was checking out the low voltage landscape lights on my house and after checkinking bukbs and wires I checked the transformer the GFI was melted and the plug on the transformer was blackened . I changed the GFI and tryed the transformer in on another line it works fine then i pluged it in to the GFI and everything works . I cant figure it out any ideas
all vinyl is offline
Old 04-29-2006, 08:42 PM   #2
DGFVT
CE1's Avatar
Trade: Electrical
Re: Burnt G F I
Maybe it got wet or the plug was loose in the receptical.
CE1 is offline
Old 04-30-2006, 12:59 AM   #3
Woz the Painter's Avatar
Re: Burnt G F I
As has been explained to me, GFI's are not foolproof, circuit breakers are less likely to blow as a fuse when there is a short.
Woz the Painter is offline
Old 04-30-2006, 07:11 AM   #4
ALL VINYL
all vinyl's Avatar
Re: Burnt G F I
I was kind of leaning toward the wet it is mounted under a deck for the last 9 years in a water proof ( i thought ) box i replaced it and built a casing on top to keep snow / rain from going directly on it . I thank you for the input . :thumbs up:
Old 04-30-2006, 05:31 PM   #5
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Burnt G F I
That is pretty scary, I would look at it again after the the lights have been on for an hour or 2 and just feel if the plug or the gfi is hot
Sparky Joe is offline
Old 05-03-2006, 12:57 AM   #6
electrical contractor
brian11973's Avatar
Trade: electrical
Re: Burnt G F I
The standard weatherproof cover is only weatherproof if the cover is closed!! Do you have a "bubble cover" ( in use cover) on this? Also check out Sparky Joes's suggestion.
brian11973 is offline
Old 05-03-2006, 10:32 AM   #7
Electrical Contractor
sundogusa's Avatar
Trade: Electrical Contractor
Re: Burnt G F I
the GFI was melted
It happens once in a while. Probably got wet. I've seen dry ones "cook" that were installed outdoors.
Brand name was Leviton
sundogusa is offline
Sump Pump burnt up..WHAT IS THIS GOOP? Jacey Plumbing 0 04-04-2007 09:21 AM
1/2 angle drills... ko_jun Tools & Equipment 15 01-10-2007 03:39 PM
Burnt motor MSSI HVAC 6 11-06-2006 07:17 AM
Brain Burnt Glasshousebltr Off Topic (Non Trade) 9 04-16-2006 09:28 AM
Burnt out somedays QDrywall Drywall 6 12-07-2005 11:05 AM
