Bulbs Dont Last In Fixture
Old 05-02-2008, 09:54 PM   #1
Jkountz's Avatar
Trade: Residential Building Contractor
Hey guys, I was hoping maybe some of you could shed some light (pun intended) on a problem Im having with a light fixture in the stairwell of my house. The light is on a three way switch one at the top and one of course at the bottom of the stairs and every time I put a new bulb in (60 watt) it only lasts for a week or two maybe a month at the most. I replaced the entire fixture last month but still the same thing. Could it be cheap or faulty switches? I cant keep a bulb in this darn thing. Its as I said located high above the stairs leading to the basement of my home. Its just a standard single bulb fixture, not an expensive one but not a $5 one either. I had a cheapo fixture there at first and thought that was the culprit but the new fixture is doing the same thing. Any ideas?
Thanks!
Jkountz is offline
Old 05-02-2008, 10:13 PM   #2
LRG WoodCrafting
Leo G's Avatar
Re: Bulbs Dont Last In Fixture
Fixture may be getting to hot. Or maybe a loose neutral.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 05-02-2008, 11:02 PM   #3
hbiss's Avatar
Trade: Electrical
I hear this all the time, it's not the fixture or the switches or the wiring. It could be crummy bulbs. Yes I know you bought brand name but they are all made in China these days. I notice that longevity is pretty much a crap shoot. Could be vibration, are there other stairs above those? What I would do is use 130 volt bulbs instead of the usual 120 volt. Might be hard to find but they are out there. Go to Bulbman.com. Another thing you might try is rough service bulbs that you would use in a trouble light. There are also vibration service bulbs. Keep both of these in mind for bathroom fans and garage door openers also.
Then of course there are always compact fluorescents.
-Hal
hbiss is offline
Old 05-02-2008, 11:14 PM   #4
troubleseeker's Avatar
-Hal
Agreed on both counts. Always worth finding the 130v bulbs, especially for difficult locations. And even the name brand bulbs are crap. Sylvania seems to be the absolute worst. Every time my electrician uses them, he ends up replacing 80% of the bulbs before we punch out the job; no exaggeration.
troubleseeker is offline
Old 05-02-2008, 11:28 PM   #5
Handle It!
MALCO.New.York's Avatar
Please delete this post.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 05-02-2008, 11:29 PM   #6
Handle It!
Are you sure the Three-Way is wired correctly?
You need to get a voltage reading on the fixture.
Old 05-03-2008, 08:38 AM   #7
dSilanskas's Avatar
Trade: Journeyman Electrician
Thanks!
A thought and an idea. Thought is that perhaps from the closing of the door is vibrating the bulb enough to blow it. And if that is the case even if its not try a twist bulb. I will bet you dollars to donuts it will fix your problem
dSilanskas is offline
Old 05-03-2008, 09:45 AM   #8
woodchuck2
woodchuck2's Avatar
I switched to the twisty's just so i wouldnt have to keep replacing light bulbs in the house. I upgraded to a more expesive bulb but they would still blow after 6-8 months. It seemed like i was replacing light bulbs somewhere in the house at least once a week. Went to the Fluorescent bulbs and i have only had to replace one of those and i had that warrantied. Power bill still hasnt dropped but at least i am not dragging a ladder in from my trailer every week to change bulbs somewhere.
woodchuck2 is offline
Old 05-03-2008, 10:12 AM   #9
Ponsse's Avatar
Trade: Electrical
yeah, you can't beat the CF in hard to reach places. I put them in everything that has a cover/diffuser where you can't see the lamp. Now if they would make them more "stylish" they could be used in even more places.
Do they make any "stylish" ones, you know like something that could be put in a ceiling fan, something other than the twisties.
Anybody using LED's yet?
Ponsse is offline
Old 05-03-2008, 12:37 PM   #10
mdshunk's Avatar
130V lamps, rough service lamps, and compact fluorescent lamps solve these types of issues.
mdshunk is offline
Old 05-03-2008, 08:29 PM   #11
MSSI's Avatar
Trade: Electrician
Vibration from the floor above and hot filaments do not mix....Rough service fan bulbs, although fan bulbs are not much better than standard, should help
MSSI is offline
Old 05-15-2008, 07:01 PM   #12
Stickman's Avatar
Trade: Tradesman / Electrician
They have a pretty good selection of c/f bulbs these days even to include dimmable. Just have to search them out.
Stickman is offline
Old 05-15-2008, 07:51 PM   #13
mdshunk's Avatar
The dimmable CF's on the market at this point are TERRIBLE!
You can call them "sorta dimmable".
mdshunk is offline
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
1st Fixture nuts are melting...any ideas why? ericjurin Outdoor Lighting 3 09-02-2007 11:56 PM
How do I support this fixture? mdshunk General Discussion 24 06-21-2007 10:01 AM
