Brick Wall
Old 04-03-2007, 12:04 PM   #1
Harry I's Avatar
Trade: electrical
Brick Wall
Hello everyone. I am fairly new to the EC business and have a small problem at hand. i need to fasten a meter base and a 2-1/2" metal stack to a brick wall. My problem is that I have never done this before. I'm looking for advice on how to do this securely so it doesn't come off the wall in the future. Thanks in advance for any info you might be able to pass on.
Harry I is offline
Old 04-03-2007, 01:20 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Brick Wall
Why would you need to vent a meter base?
Magnettica is offline
Old 04-03-2007, 02:36 PM   #3
Old Guy
househelper's Avatar
Trade: Electrician (semi-retired)
Re: Brick Wall
The electrons won't drain properly without a vent. Everybody knows that!
househelper is online now
Old 04-03-2007, 03:14 PM   #4
Electrical Contractor
jbfan's Avatar
Trade: Electrical Contractor
Re: Brick Wall
Unistrut and tapcons, or drive pin anchors is what I would use.
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 04-03-2007, 05:07 PM   #5
mickeyco's Avatar
Trade: Squirrel Handler
Re: Brick Wall
Scotch 3M Double Sided Tape or some masonary anchors (there's a bazillion types) or tapcons.
mickeyco is offline
Old 04-03-2007, 06:11 PM   #7
mdshunk's Avatar
Re: Brick Wall
For hard brick, I use Rawl plugs and #12 x 2" Hex washer head screws. For soft brick, I use 1/4" lead lag shields and 1/4 x 2" lag bolts. For brick that's crumbling to bits, I mount strips of Kindorf with as many lags as I can get to hold a little bit, and attach the meter can to the Kindorf with spring nuts.
Sometimes you can over think stuff.
I will add that they guys behind the counter at Fastenal are fantastic when it comes to figuring out what the best thing to use to attach "A" to "B" would be. Most areas have a Fastenal somewhere.
mdshunk is offline
Old 04-03-2007, 07:39 PM   #8
DGFVT
CE1's Avatar
Trade: Electrical
Re: Brick Wall
Surprised somebody didn’t suggest using duct tape.
3/8" caulking anchors or unistrut.
CE1 is offline
Old 04-03-2007, 09:30 PM   #9
mdshunk's Avatar
Re: Brick Wall
Uh-huh?
How do you do that when the equpment only has 1/4" mounting holes?
mdshunk is offline
Old 04-03-2007, 10:49 PM   #10
macmikeman's Avatar
Trade: Master Electrican, Electrical Contractor
Re: Brick Wall
I cut a piece of treated plywood the size of the meter socket, liquid nails the begoinias out of the backside of that and then tapcon it to the brick where you want the meter to ride. Screw the meter can to the backboard. Once the nails dries up, Nancy Pelosi could not budge it.
macmikeman is offline
Old 04-03-2007, 11:20 PM   #11
mdshunk's Avatar
Re: Brick Wall
Originally Posted by macmikeman View Post
I cut a piece of treated plywood the size of the meter socket, liquid nails the begoinias out of the backside of that and then tapcon it to the brick where you want the meter to ride. Screw the meter can to the backboard. .
Oh, c'mon. Seriously? That's just weird.
mdshunk is offline
Old 04-04-2007, 12:13 AM   #12
JamesNLA's Avatar
Trade: Plumbing & Electrical
Re: Brick Wall
She could get it off. She has those new demacratic dentures that can chew anything off. MAybe someone outta feed her some treated ply...might do the country some good
JamesNLA is offline
Old 04-04-2007, 07:37 AM   #13
DGFVT
CE1's Avatar
Trade: Electrical
Re: Brick Wall
Originally Posted by mdshunk View Post
Uh-huh?
By using ¼-20 to 3/8-16 threaded adapters of course.
Attachment 5100
A 2 ½’ 1 hole pipe strap has a ½” mounting hole, so 3/8” is a happy medium.
When Rome was built they didn’t scrimp on size and see how long their stuff lasted.
CE1 is offline
Old 04-04-2007, 05:50 PM   #14
mdshunk's Avatar
Re: Brick Wall
I'd have just drilled the holes bigger.
mdshunk is offline
Old 04-04-2007, 06:06 PM   #15
DGFVT
CE1's Avatar
Trade: Electrical
Re: Brick Wall
I would of used 1/4-20 anyway. Brick walls are sometimes are real pain trying to mount equipment on. Only thing worse is trying to mount panels on fieldstone foundations in basements. Sometimes you have to creative in getting them mounted. Plus a low ceiling hight in old basements causes problems also. Sometimes I wish I was a foot shorter, it would make working in old basements a lot easier.
CE1 is offline
Old 04-05-2007, 12:06 AM   #16
macmikeman's Avatar
Re: Brick Wall
Seriously. Works real well. But I don't paint backboards. That is for someone else to do.
Old 04-05-2007, 01:48 AM   #17
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Brick Wall
That's an interesting way to go about doing work for people. Give the people there moneys worth. Now there's a hell of a concept!
Old 04-05-2007, 06:33 AM   #18
mdshunk's Avatar
Re: Brick Wall
Yes, but Rome wasn't built in a day. Services are usually built in a few hours.
mdshunk is offline
Old 04-05-2007, 04:04 PM   #19
DGFVT
CE1's Avatar
Trade: Electrical
Re: Brick Wall
Keep up the good work!
You’ll get there, Marcus Electhrus.
CE1 is offline
SUB-CONTRACTOR needed to build(give estimate) red brick or block(stucco finish) wall( soldz Masonry 18 04-22-2007 09:55 AM
wire behind brick hurricaneflyer Electrical 7 11-13-2006 08:03 PM
Pipe through brick wall gnahthe Plumbing 12 10-01-2006 01:08 PM
6' anderson sliding doors in brick wall keithguts Windows, Siding and Doors 7 01-24-2006 09:23 AM
