Trade: commercial hvac repair and installations
Breaking The Neutral..GENNY INSTALL
i have a generator tied into my house panel and a disconnect switch to isolate the pole legs coming in 2-115V...220V across. my question....should i break the neutral coming in also even that it goes the grounding bar that all the house neutral(whites)come back to from the loads within the house sockets.i work on 230/460 3 PHASE equipment for a living HVAC field. basiclly thinking the Gen neutral will feed up the pole into the utilities lines???? when running
Re: Breaking The Neutral..GENNY INSTALL
I just went through all of this with my sparky yesterday. His opinion was to check the neutral for stray current and then forget about it. The box should be grounded according to NEC and, if any strays are produced, they should go there before going back up the line.
Union Electrician
Trade: Inside Wireman
Hard to understand everything you said.
Basically the transfer switch you buy decides whether or not the neutral is going to be switched. If the the neutral is switched then you'll need to bond the neutral to the ground at or before the transferswitch on the gen side(only one place though) If the neutral is not switched, it's a pretty standard hook up, black to black and so on, and make sure you ground and bond everything correctly. Last edited by Sparky Joe; 07-03-2006 at 06:38 PM. |
#4 | |
Re: Breaking The Neutral..GENNY INSTALLQuote:
Union Electrician
Can't the two be bonded at the first point of disconnect?
| 55 volts on both hot and neutral, what the heck!? | karma_carpentry | Electrical | 32 | 02-28-2009 09:12 AM |
| Need help with a shocking outside waterspout | Badoish | Electrical | 23 | 12-27-2008 04:18 PM |
| Reverse feed a broken neutral - K & T wiring | mdcorreia | Electrical | 3 | 04-06-2007 06:53 PM |
| Shared neutral with a GFI | darren | Electrical | 21 | 03-03-2007 06:38 PM |
| Alright businessmen ... I'm gonna give it one more try ... breakin even | dirt diggler | Business | 30 | 02-27-2007 12:34 PM |
