Breaker Panel Question?
Old 07-26-2004, 09:56 AM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
I have a duplex and the breaker panel is inside a closet of a finished basement. The main breaker for the panel is out side the house next to the meter. Both sides of the duplex are like this. Woudl the panle in the closet be a sub planel
Old 08-05-2004, 09:48 AM   #2
Unregistered
Guest
Posts: n/a
Lightbulb
Re: Breaker Panel Question?
The reason for the Main breaker on the outside near the meter might have to do with the distance from where the sevice wire is feeding from the meter to where it is going to be breaker panel. There is a distance requirement that the breaker panel has to be within so many feet of the meter. If it isn't, then a main breaker has to be installed. It's a safety precaution. The only other reason I could think of is it could be somekind of local code required.
Old 08-15-2004, 02:51 PM   #3
Unregistered
Guest
Posts: n/a
YES its a sub and its needs a 4 wire from dissconect to panel
Old 09-05-2004, 09:40 AM   #4
Unregistered
Guest
Posts: n/a
Sounds like there is simply a "meter main" on the outside of the house, probably a 2 pack for both sides and one disconnect for each side?
If thats the case then your only panel is the one in the basement. I wouldnt call that a SUBpanel but is does require 4 wire to feed it. And I hope it isnt in a CLOTHES closet.
Restaurant sub panel Forry Electrical 21 06-11-2007 08:42 AM
No main disconnect at customer breaker panel RandyMc Electrical 3 09-24-2006 12:50 PM
2 part question ron schenker Electrical 10 02-21-2006 10:36 PM
How many Breakers in a panel robertc65 Electrical 2 02-21-2006 02:09 PM
Upgrading Main Panel DecksEtc Electrical 7 01-23-2006 07:54 PM
