Breaker Panel
Old 01-26-2004, 12:27 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Question
Breaker Panel
I posted this on the DIY board but I think there might be some more qualified responses from this one...anyhow,
I'm remodeling my basement bathroom and need to put in two new 15A breakers to complete my electrical needs. In order to fish the new wires to my breaker panel, which some wise-guy located in a finished bedroom closet, I need to remove my breaker panel and drill through to my utility room. My question is, how do I de-energize the breaker panel so that I can move it completely out of the cubby hole it is in now? I know I can switch off the main power coming into the house, but is this enough? Do I have to call the electric company to shut 'er down while I remove the panel, drill and fish, and reinstall? It is necessary for me to remove all breaker wires, etc. so that I can move the box... so what should I do with the hot wire coming in? Thanks!
Old 02-01-2004, 09:31 AM   #2
Chip
The Electrician's Avatar
Re: Breaker Panel
Make sure that there is no other way to get this wire in the panel because that will be a pain in the ass removing a panel for two circuits. It may be possible to drill through the back of the panel to get your access, or utilize one of the knockouts, if there are any. To answer your question, if the main breaker for the house is located at the meter base and not in the panel, once you shut it off your panel will be off. If the main is located in the panel, you need to first turn it off so there is no draw on your house, and then remove the meter can cover and pull the meter.
The Electrician is offline
Old 02-03-2004, 01:19 PM   #3
Awaiting Email Confirmation
Itsahipo's Avatar
Location: Southern Maryland about 25 miles south of Washington D.C.
Re: Breaker Panel
There has to be a better way. After 23 years of this I have never moved a panel box to pull two circuts.
Itsahipo is offline
Old 02-09-2004, 04:22 PM   #4
Mats's Avatar
Re: Breaker Panel
Make sure you measure that the panel is not live after you've disconnected it. Don't just rely on the breaker knob being in the "0" position.
Mats is offline
Old 02-17-2004, 10:17 PM   #5
Unregistered
Guest
Posts: n/a
Re: Breaker Panel
Hire an electrician. You don't know what you're doing. You'll thank me later.
Restaurant sub panel Forry Electrical 21 06-11-2007 08:42 AM
No main disconnect at customer breaker panel RandyMc Electrical 3 09-24-2006 12:50 PM
How many Breakers in a panel robertc65 Electrical 2 02-21-2006 02:09 PM
Upgrading Main Panel DecksEtc Electrical 7 01-23-2006 07:54 PM
