Breaker Finder
Old 07-05-2005, 10:14 PM   #1
toastermaker's Avatar
Trade: electrical
Breaker Finder
If there is such a thing as a "basic" circuit breaker finder, can it (or any other tester) identify a breaker from only the hot wire or is the neutral needed also?
I have never seen a breaker finder, but was thinking of buying one.
I asked this particular question because I am semi-frequently faced with tracing a circuit to find a shorted or absent neutral connection, and wondered if a breaker finder would work under those conditions.
Thank you for any replies and help,
toastermaker is offline
Old 07-05-2005, 10:30 PM   #2
mdshunk's Avatar
Re: Breaker Finder
Man... I don't know of one. Even if it was a de-energized circuit, you'd still need at least two good conductors to use a fox and hound type tracer. I know you could do it with one conductor with an underground tracing rig if you set the sensitivity way down, but now you're in the thousands of dollars. For a circuit without a neutral, I tend to use a non-contact voltage probe held on the conductor by the helper and a set of two way radios and start flipping breakers. If you're in a commercial setting, you can't really use that method without getting run out of the place. If you must find the breaker, and the neutral is absent, .... err ... I hate to suggest it but we've all done it... hard short it to ground and the breaker will declare itself.
Best I got.
mdshunk is offline
Old 07-05-2005, 11:21 PM   #3
Trade: electrical
Re: Breaker Finder
Thanks for the reply mdshunk.
I can use your ideas. Much appreciated.
easylaterT
Old 07-05-2005, 11:21 PM   #4
housedocs's Avatar
Trade: Home Improvement
Re: Breaker Finder
:Thumbs: Yep that'll find it in short order, you have the helper do that too? :Thumbs:
"All you need in this life is ignorance and confidence, and then success is sure". -Mark Twain
housedocs is offline
Old 07-06-2005, 12:20 AM   #5
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Breaker Finder
I have an Ideal breaker finder. It is a simple standard plug in tester with the three LED's and a GFI tester. But it also is the sender for the handheld beeper you run down the breakers to find the one feeding that circuit.
I know there are cheaper ones, although this one was not too bad, but I'm not sure if this one is still made.
Speedy Petey is offline
Old 07-06-2005, 08:44 PM   #6
Trade: electrical
Re: Breaker Finder
Thanks again everyone,
Speedy, does the finder you speak of still work if there is no neutral?
Thanks,
Old 07-06-2005, 09:53 PM   #7
Trade: Electrical
Re: Breaker Finder
I can't say for sure but I would guess it would. As long as the ground is intact.
Actually Ideal does have a couple of different versions available. I noticed today my supply house has two different ones on the rack.
Old 07-06-2005, 11:05 PM   #8
Trade: electrical
Re: Breaker Finder
Thanks again,
The two electrical supply houses in my area dont seem to sell very many tools, so I looked for one today a Lowes and Home depot. There I found a few differant models but the info on the outside of the packages only talks about how great and simple they are. There is no instructional or how-to info that I could find on any of the packages that would answer my question about working without a neutral.
Thanks,
Old 07-19-2008, 10:30 PM   #9
stp57's Avatar
Trade: carpenter/ handyman
Re: Breaker Finder
Wow, this is an "oldie" thread. I have noticed that there are three breaker finders (that I know of); Ideal, Sperry & Hi-Tech. They all are in the mid $30 range & all have a transmitter that plugs into the outlet & a receiver that you wave over the breaker box once to program & the second time to locate the right breaker. Any body here know if one works any better than the others?
Steve
stp57 is offline
Old 07-19-2008, 10:54 PM   #10
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Re: Breaker Finder
I use this one - not very fancy, but has worked fine for me on single phase panels.
I also have the accessories that you can get (not shown) where I can screw it into a lamp socket, or a set of alligator clips.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 07-19-2008, 11:17 PM   #11
mdshunk's Avatar
Re: Breaker Finder
You guys might not have noticed that the OP is looking for a 'breaker finder' that will work with only one conductor.
mdshunk is offline
Old 07-20-2008, 08:37 AM   #12
stp57's Avatar
Re: Breaker Finder
Oops, you are right once again MD. Oh well, it was the only breaker finder post on the whole Forum. It is amazing how you have not aged in your photos from 2005 to now & not a whisker hair is out of place. Ha ha, I know that is not your photo.
I have found several more brands of breaker finders since yesterday. The technology seems similar, but I'm sure at least one of them stands out as being more reliable.
Steve
stp57 is offline
Old 07-20-2008, 10:00 AM   #13
mdshunk's Avatar
Re: Breaker Finder
Originally Posted by stp57 View Post
...I have found several more brands of breaker finders since yesterday. The technology seems similar, but I'm sure at least one of them stands out as being more reliable.
You're right. That would be the Amprobe AT-2005
mdshunk is offline
Old 07-20-2008, 10:43 PM   #14
stp57's Avatar
Re: Breaker Finder
Wait...let me go pawn a few things first! Ebay = $935.
Steve
stp57 is offline
Old 07-24-2008, 06:00 PM   #15
wirenut1110's Avatar
Trade: Electrical
Send a message via AIM to wirenut1110
Re: Breaker Finder
I think this may be what you're looking for, I know it's on my list of things to try. Google Greenlee model 2011 circuit tracer.
wirenut1110 is offline
Hot dryer breaker HandyAl Electrical 7 08-19-2008 05:34 PM
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
t-shoot gfci breaker hurricaneflyer Electrical 10 11-14-2006 08:56 PM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
gfci breaker Browny Electrical 6 05-29-2006 07:45 AM
