Trade: electrical
Branch Circuits
What are the maximum run (in feet) on 15 A using #14 Awg and 20 A using #12 AWG branch circuits from the main breaker in residential?
General rule is 5% voltage drop from utility company drop. But I can not find anything in black and white in Article 310. Any body has any information, I'm surely appreciated. Thanks, Louis
Louis Bugaj |
Re: Branch Circuits
The code does not provide any minimum or maximum voltage drops. That's a design issue and not a safety issue.
The rule of thumb is 3%. For a fully loaded 15a, 120 volt circuit with #14 wire, your max run at 3% drop is 45 feet. at 240 volts, 90 feet. For a fully loaded 20a, 120 volt circuit with #12 wire, your max run at 3% drop is 55 feet. at 240 volts, 110 feet. |
Trade: electrical
Re: Branch Circuits
Thank you MD. I wonder how the highend houses passed the inspection.
Louis Bugaj |
#4 | |
Electrical Contractor
Trade: Electrical
Re: Branch CircuitsQuote:
Also, remember the numbers Marc gave you are fully loaded circuits. No circuit should ever be fully loaded, except for maybe for a short time. This is because there are so many circuits in a home, and anything heavily loaded is usually accounted for.
Professional Remodeler
Re: Branch Circuits
Petey is correct, a circuit should be loaded to more than 80% or it's rated capacity- 15 amp circuit...12 amps max and a 20amp circuit... 16 amps max
#6 | |
Re: Branch Circuits
Is there a big difference in being a commercial electrician and a residental. Because if i was a electrician like you guys i think it would be awesome to work on a electric crew that was wiring a brand new skyscrapper in chicago. So i guess my question is this. Could you guys get a job on a electric crew building a new skyscrapper and know what your doing or is that a completely different ballgame then residental.
Trade: Consultant
Re: Branch Circuits
The theory is the same, the application is different. A lot depends on your training. If you became an "electrician" by nailing up boxes where someone told you to, pulling lots of Romex to boxes and learning how to install an outlet properly, you're still a long way from being able to do commercial work. If you've got through a formal apprenticeship program, you've got a better grip on theory (the reasons "why" you're doing what needs to be done), as well as the hands-on training with conduit, pulling feeders, etc.
In general, commercial work is a lot more involved than residential- especially when you bring up the skyscraper example. Ever seen the switchgear in a 50-story building? Quite a bit different than your 100A panel at home Bob |
listen twice talk once!
Trade: electrician
Re: Branch Circuits
Hey MD are saying a fixed appliance or dedicated circuit can be loaded 100% in residential. I know lighting circuit can be and general purpose outlets it's hard to say because of the variable's of whats being plugged in. bk
#10 | |
| Seperate circuits grounds and neutrals | davidchomes | Electrical | 44 | 09-03-2007 10:57 PM |
| Electrical Box removing and disconnecting circuits | MikeT | Electrical | 9 | 08-15-2006 06:07 AM |
| Standard way to wire lighting circuits | robertc65 | Electrical | 9 | 03-08-2006 02:18 PM |
| Residential General Lighting Circuits | toastermaker | Electrical | 11 | 02-26-2006 01:04 AM |
| Using 12/3 to power Two Circuits | robertc65 | Electrical | 18 | 02-16-2006 12:26 AM |
