tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Bonding Bushings
Old 06-05-2009, 12:36 AM   #41
huntington beach, ca.
hbelectric's Avatar
Trade: electrical
Rewards Points: 250
Re: Bonding Bushings
Originally Posted by dmanola7 View Post
Why wouldn't you use rigid?
Realistically how much is that going to cost you, time (cut&thread) and material. Running 1" or 1 1/4? If you are not going to C&T, your connector is not cheap, might as well use EMT at that point.
I look at a job and I decide what I 'm going to use, so it's not cut in stone. You may think about some sced 80 pvc, looks a little better than sced40, will last longer, never rust and you won't need a bonding bushing.
I would run either sced80 pvc or EMT, not sure which one without looking at the job.
hbelectric is offline
Old 06-05-2009, 07:57 AM   #42
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
For what it is worth my inspector wont pass anything whether it is EMT, Rigid or PVC regardless of wire size unless it has bushings at each end. He has told me that if i can see the end "tip or edge" of the nipple "male adapter" then put a bushing on it, and for the cost of the bushing why chance compremising the wire or having to take apart your work just to put a bushing on to satisfy your inspector. The cost is minor and should be passed on to the customer, oh hell we are making money on these items are we not? If you are working with EMT or Rigid he wants to see that it is also bonded. IMO i would install PVC and 4-wire and be done. This is how i do most sub-panels unless distance is an issue, then i will drive another set of rods and ground the sub-panel at the other location.
woodchuck2 is offline
Old 06-05-2009, 11:01 AM   #43
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
I was simply pointing out the required code minimum. You want to put 1/2" bushings on emt connectors be my guest.
Magnettica is offline
Old 06-05-2009, 11:19 AM   #44
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 264
I would ask him for the code reference
TxElectrician is online now
Old 06-05-2009, 08:54 PM   #45
220/221's Avatar
Trade: electrician Phoenix AZ
Thanks Magnettica, from now on your the man Im gonna run to for the CORRECT answers.
TX gave you the right answer. He even made you think a little about it.
Bond bushing on one end if the nippple has the service conductors in it or if it has concentric KO's and voltage over 250 to ground.
I had an inspector ask me about bond bushings on a panel one time. I pointed out that they were feeders with a ground (not unfused service conductors), the voltage was 120 to ground and that BB's weren't necessary.
He spent a half hour in his truck searching a code book before he came back and said "oh....I see now that you have locknuts inside and outside , so it's OK".
I laughed (to myself)
PS. When it's close, I use rigid nipples to tie enclosures together. Rust isn't an issue with exposed galvanized here in the desert unless it's in contact with the soil. THEN it's a REAL issue. If the enclosures are more than a few inches apart, I use EMT. It just seems better suited. Metal cans joined by metal conduit.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 06-05-2009, 08:59 PM   #46
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Rewards Points: 516
you are right it may not be code but for a few pennies dont worry about the aggrivation(sp)
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 06-05-2009, 09:04 PM   #47
ampman
ampman's Avatar
Rewards Points: 516
ok i'am confused you had a feeder that was only 120 v to ground
ampman is offline
Old 06-05-2009, 10:22 PM   #48
hbelectric's Avatar
Trade: electrical
Rewards Points: 250
Yeah I was just referring to him running rigid, point taken
Old 06-07-2009, 09:34 PM   #49
luckyshadow's Avatar
Trade: electrical professional
Rewards Points: 33
Cut and dry answer--> You do not have service conductors, you have concentric/eccentric knockouts and
A) your voltage is under 250 volts to ground --> NO Bond Bushing Needed
B) Your voltage is OVER 250 volts to ground --> Bond Bushing Required
I'm willing to bet your voltage is under 250 volts as you say it's a doctors HOUSE
NO Bond bushings needed just use a plastic bushing an be done with it.
luckyshadow is offline
Old 06-07-2009, 09:42 PM   #50
220/221's Avatar
uhhmm...yeah?
120/240 single phase residential service=120V to ground. Is that unusual?
220/221 is offline
bonding agent for stone driveway rocknhammer Specialty Trades Picture Post 5 09-28-2008 07:25 PM
insurance and bonding 3ndAhammer General Discussion 2 09-10-2008 09:37 PM
bonding agent ApgarNJ Masonry 10 05-09-2008 11:16 AM
System Bonding Jumper vs. Main Bonding Jumper Mark Twenhafel NEC Discussion 3 02-09-2008 06:15 PM
Bonding for new home building TNGHomes Construction 5 01-28-2008 04:20 PM
