Blowing Light Bulbs
Old 12-23-2007, 01:22 PM   #1
Bob H's Avatar
Blowing Light Bulbs
Over the years, I have run into numerous houses, which have a problem with light bulbs prematurely burning out. The problem is usually is limited to one circuit. There does not appear to be any problem with overloading or box overfill. The only thing that has helped is putting in bulbs rated for 130 volts. Anyone have any ideas on what could be causing the problem?
Bob H is offline
Old 12-23-2007, 01:44 PM   #2
Electric_Light's Avatar
Trade: student again
Re: Blowing Light Bulbs
High line voltage. Every 5% increase in line voltage halves the life. For Chandeliers and such where bulb replacement is particularly difficult, use a dimmer switch that does not hold the setting, so the light is ramped up and dim it just slightly below max.
The ramping significantly reduces the likelihood of the lamps going out with a flash when they're turned on. Dimming slightly below max significantly extends life. If you lower the voltage 5%, you double the life, lower 10%, you quadruple the life.
That circuit might simply not have any other load to lower the voltage the few percent. What's the line voltage?
Electric_Light is offline
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
Lamps (light bulbs) NightScenes Outdoor Lighting 13 10-25-2007 01:32 AM
Problem with a fan light wackman Electrical 3 10-23-2006 04:13 PM
Light bulbs Teetorbilt Electrical 17 02-11-2006 02:54 PM
Definition of a true forum ProWallGuy Off Topic (Non Trade) 6 07-06-2005 07:10 PM
