Union Electrician
Trade: Inside Wireman
Battery Charger
I've been working in a private jet hanger for the past few days. The guys there asked me to temporarily hook up a bat charger for their new tug.
They wanted it temporary because the charger will have a different final home if this job ever ends. It runs 208/240(single phase) and reads 26amps(at 208). Their one 208 panel is full, but they had a 208/20A receptacle already in the hanger, so I installed the cord cap they already had and said there was a chance(if the batteries weren't deeply drained)it would work. But it tripped. So there was a 3 phase 30A breaker in the panel for one of the air conditioners, I piggybacked the charger onto this(mind you this is temp) seeing as it's been 10 degrees here. After 20 minutes it tripped. I clamped the wires and read 46 amps. There is a 50A 2pole breaker for the range in the kitchen which is never used, and told them I could tie to that, but want them to first call the manufacturer of the charger and ask if this is a normal current reading. My questions; Has anyone seen a battery charger(72V 40A output) draw a current higher than the nameplate? I know they vary due to depletion of the battery being charged. Next; what are the feelings of tapping off two legs of a 3 pole breaker, I know it was stupid, but why? And; If I do put it on the 50A breaker should I keep the 30A recep and cord cap I already installed. Are the hazards really that significant? Keep in mind all this is to try and help and customer dodge an inflated charge of doing the same job 3 times(though my work compared to five 40million jets is hardly inflated), and also that any comments will be supersceded by what my shop says in the morning, although some knowledgeable info is very appreciated. Afterall who wants to just do what they are told, knowledge is key to making decisions. -Joe |
DGFVT
Trade: Electrical
Re: Battery Charger
Joe,
Check you data again some of the numbers don't add up. What you have, I can not tell. Last edited by CE1; 01-17-2007 at 08:01 PM. |
#3 | |
Union Electrician
Re: Battery ChargerQuote:
The charger was a multi tap for single phase 208 and 240, all that checked out and even the amp meter on the charger read 40amps DC, which is what it says it needs. |
Trade: Electrician
Re: Battery Charger
As far as the plugs go....being able to plug a 30A circut into a 50A breaker is probably not a good idea.(in this environment even if very tempoary) The equipment that floats around an aircraft hanger can be quite expensive (think flight control diagnostic equpiment)and is often under the umbrella of the FBO(fixed base of operations)Which is governed by FAA guidelines. I wouldnt want to try to explain my way out of burning down a $25mil Gulfstream. The first thing they teach an aircraft mechanic is not to put your name on your tools..(lol) picture you new 7/8 snapon wrench getting sucked into a turbine engine...You dont want to be the one they come looking for.
An Aircraft Battery charger has voltage regulated circutry I dont think there is a direct corelation between load on the battery side and amp draw on the line side. I believe the same holds true for a Standard battery charger.. If the tag reads 26 amps it probably shouldnt be drawing 46??? It sound like we might be missing something.. |
Union Electrician
Re: Battery Charger
Thanks MSSI, good points about the higher regulations of doing work around aircrafts. My Dad worked for Douglas when they were still around and had something called "FOD free" which had something to do with foreign objects. They had inspectors watching these DC-10's being built from start to finish and when the entire plane was complete, the inspectors would say back on 'such and such' day 'so and so' left a 3/8 socket(or whatever) in a specific part of the plane. What then, tear it apart and find it.
Trade: Electrician
Re: Battery Charger
sometimes the tugs use the same battery setup as the aircraft.Or it could be a 24V diesel setup..... probably to late but is this a walk behind tug(electrohydraulic ?) ..72v is an aircraft voltage....Thats 6 batteries in series.... there should be settings on the charger for 24 and 48 volt as well. make sure the batteries you are trying to charge corespond with the charger setting.
Trade: Electrician
Re: Battery Charger
oh ...and aircraft battery arrays can be upwards of $30K
DGFVT
Trade: Electrical
Re: Battery Charger
Hey Joe ,did you get it hooked up or not. Some people need to know you know.
#9 | |
Union Electrician
I get there today and asked if they called the manufacturer, they said "no, they just changed the tap to 240 and it works fine". I thought about opening the panel and checking the current again, but also thought, "if it aint broke....". Just to satisfy curiosity, next time I'm in the panel I'll hook up the charger and check the current. Then I'll post. I just didn't want to be the one to blow the thing up, but of course I'm the one that looks the idiot now |
Trade: CA: Electrical
Re: Battery Charger
Better safe than sorry. If you had hooked it up and the worst did happen you wouldnt live it down
DGFVT
Trade: Electrical
Re: Battery Charger |
Union Electrician
| Dewalt battery question | Heritage | Tools & Equipment | 54 | 10-22-2009 05:25 PM |
| Crew Charger | Mike Finley | Tools & Equipment | 9 | 06-25-2007 02:34 AM |
| Battery tester question | Mike Finley | Electrical | 49 | 03-16-2007 12:13 AM |
| Your thoughts on this car | ron schenker | Off Topic (Non Trade) | 46 | 03-15-2006 10:15 AM |
| Battery powered grease guns | denick | Excavation & Site Work | 8 | 02-17-2006 02:55 PM |
