#1 | |
Bathroom Exhaust Fan And Minimum Distance From Shower
I'm wondering if bathroom exhaust fans fall under IRC E3903.10?
Service & Repairs
Trade: Electrician
Re: Bathroom Exhaust Fan And Minimum Distance From Shower
That IRC Code seems a lot like the one we have in the NEC, article 410.4 (D). It basically states that no light fixture other than a recessed-type can be mounted within' 3' of the edge of the basin (tub) unless it's 8' high or greater. Most exhaust fans are rated for damp locations so you should be fine. Check the manufacturer specs to see if it needs GFCI protection.
Good luck. |
All right, thanks. I found the Broan 744 which seems like it should work very well for the location. It's a recessed light/fan combo U.L. listed for use over bathtubs and showers when connected to a GFCI protected branch circuit.
You can put the exhaust fan actually in the shower if you want to. Some builders I wire for want it done just that way. Most of them have a sticker inside that says you need to GFCI protect it somehow if it's in the tub or shower zone. I guess Mag just said all that, huh?
Well, now I second it! |
Can't be right.
That would exclude fans from half the ¾ bath in the country.
#6 | |
Service & Repairs
Trade: Electrician
Re: Bathroom Exhaust Fan And Minimum Distance From ShowerQuote:
I just bought a new iMac the other day so I am cruising full-speed.
Historic specialist
Trade: General B100 Utah
You could use the fans that mount an intake in the ceiling and then remotely place the fan motor far enough away. I mostly install the fan/can combo. one inspector wanted to see a shower trim, hmm, hows air supposed to go through that? he let logic win over books.
TD www.EnoceanWireless.com Wireless lighting control, without using batteries Use the Discount Code "Contractor" if you'd like... |
Trade: Carpenter joiner
As most shower bathroom exhaust fans extract steam and air to the outside of the building thus drawing out the warm air. Would anybody know of a system in Australia available that extracts the steam and recycles the warm air back into the room.
And I do electrical, too!
Wow. Resurrect a 2 years, 2 month, and 22 day-old thread. Is this a CT record?
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Not even close....
