Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 04-10-2009, 08:37 PM   #1
Trade: RESIDENTIAL REMODELING
Bath Fan/heater
Replacing bath fan/light/heater, says must be on 20 amp dedicated circuit.
Current fan/heater/light is on dedicated circuit, 12 gauge from panel to three switches then 14 gauge(2 14/3 romex) from switches to fan/heater/light.
Breaker in panel is 20 amp.
Question?? Is the 14 gauge between the three switches and the fan/light/heater ok or must it also be 12 gauge.
Thanks
John
John1 is offline   Reply With Quote
Old 04-10-2009, 08:39 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
Should be 12 ga. If the current draw of the unit doesn't exceed 15 amps you could/should change the breaker to a 15 amp.
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
John1 (04-10-2009)
Old 04-10-2009, 08:56 PM   #3
Trade: Electrical Helper
Not legal, put it on a 15 amp breaker or change the 14 ga to 12 ga.
crazyboy is offline   Reply With Quote
Old 04-10-2009, 11:16 PM   #4
Remodeler Extraordinare
A.W.Davis's Avatar
Change the switch legs to 12 gauge. Do not change the breaker to a 15 amp breaker when the specs require a 20 amp breaker.
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline   Reply With Quote
Old 04-11-2009, 12:04 AM   #5
God Bless America
Magnettica's Avatar
Trade: Electrician
Checkout 110.3(B) and you tell me.
Classic Electric LLC
Repairs, Renovations, Rehabilitation
Magnettica is offline   Reply With Quote
Old 04-11-2009, 07:41 AM   #6
A.W.Davis's Avatar
D'ohh I hate it when my warranty is voided.
Old 04-11-2009, 09:23 AM   #7
Old 04-11-2009, 03:19 PM   #8
God Bless America
Magnettica's Avatar
Trade: Electrician
I was going to say if the fan says nothing about needing an individual 20 amp circuit to change the 20 amp breaker to 15 amps. Of course this depends on the wattage rating on the fan but still a lot simpler than changing the switch legs out to #12.
15a x 120v =1800 watts.
Old 04-11-2009, 10:06 PM   #9
He said it says it must have a 20 amp dedicated circuit so I think hes only got one option
Old 04-11-2009, 10:45 PM   #10
God Bless America
Magnettica's Avatar
Trade: Electrician
the simplest way to do this then is to run a new 20 amp ckt and switch leg. Messing with the old wiring really adds to labor time.
Old 04-11-2009, 11:03 PM   #11
Trade: Journeyman Electrician IBEW
No he's already got the #12 awg. from breaker to switches, it's from the switches to the fan/heat/light that the #14 kicks in. Original installer was probably thinking each of the 3 switchlegs is less than 15a so what the hay...
Changeout the 2 14/3 switchlegs to one 12/4 and you're golden.
LawnGuyLand is offline   Reply With Quote
Old 04-15-2009, 07:54 PM   #12
Trade: Home Theater Design & Installation
I have to fix a similar issue in my own home...
20A circuits that have 14/3 wired between the two switches, but the rest of the wire is 12/2.
This was done on two circuits in the house. I assumed he didn't have any 12/3 on his truck.
If am I not mistaken, wire guage must remain the same on the entire circuit, regardless of the CB being used.
philcav7 is offline   Reply With Quote
Old 04-15-2009, 07:56 PM   #13
LRG WoodCrafting
Leo G's Avatar
The circuit breaker must be sized for the smallest wire in the circuit.
Carpenter by day.
http://lrgwood.com
Bath ventilation fan/heater combo drb9 Kitchens & Baths 5 12-22-2008 09:13 AM
tile backer in a bath room and kitchen mikeybobo Drywall 10 12-05-2008 04:31 PM
Bath area rock ??????? Driftwood Drywall 9 11-24-2008 09:35 AM
1/2 bath to 3/4 bath home improvement wilsonkori General Discussion 1 11-11-2008 11:58 AM
upper bath woodlover Remodeling 14 04-21-2008 09:55 PM
