tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Ballast Plug Wiring
Old 02-22-2018, 09:51 PM   #21
ComRemodel's Avatar
Trade: electrical
Rewards Points: 140
Re: Ballast Plug Wiring
Originally Posted by P42003 View Post
The thing that concerns me is that "supposedly" the "output" is to a male end, rather than a safer female socket. That's why I wonder if he doesn't have this thing all jacked up. Hopefully we'll get to find out if there's smoke or not, and I don't mean the type he's growing.
Just look at the market this crap is for. Not much of anything for it is manufactured to comply with UL or any codes or even common sense. Designed by a bunch of pot heads for pot heads.
-Hal
ComRemodel is offline
Old 02-27-2018, 12:22 PM   #22
memetic's Avatar
Trade: Architect/General Contractor
Rewards Points: 115
Originally Posted by ComRemodel View Post
If you check continuity from the ground prong on the line cord to the prongs on that plug you should be able to see which is the ground. The other two go to the terminals on the socket, doesn't matter which is which. So all you have to do is identify the ground and you know the other two go to the lamp socket.
If you cut the plug off it looks like there will be a green ground and a black & white. Black and white goes to the socket. Green ground goes to whatever fixture you have holding that socket.
-Hal
Yes, thank you. You were correct, of course. It turned out to be very simple. I got it wired now.
memetic is offline
The Following User Says Thank You to memetic For This Useful Post:
SmallTownGuy (02-27-2018)
Old 02-27-2018, 12:25 PM   #23
memetic's Avatar
Rewards Points: 115
-Hal
You have no idea what you are talking about. Are you drunk?
memetic is offline
Old 03-01-2018, 09:32 AM   #24
ComRemodel's Avatar
Trade: electrical
Rewards Points: 140
Having dealt with other "grow light" equipment questions and seeing what's out there, that's the only conclusion a knowledgeable professional in the electrical trade can make. Because pot has been legalized here for some uses, some people want to cash in and become growers. So all the junk that was hidden previously in basements away from law enforcement now becomes legitimate.
What are you using it for?
-Hal
Wiring up furniture lights with a ballast HomeSouthern Electrical 1 09-20-2017 05:14 PM
How to properly hook a generator up to a plug to run sump pump reweb Electrical 4 01-19-2017 10:50 PM
Fluorescent ballast wiring rservices Electrical 3 01-10-2016 07:19 AM
Todays wiring rotarex Electrical 11 06-15-2013 03:41 PM
Explanation for wiring? CarpenterSFO Electrical 42 04-05-2013 10:50 AM
