Ballast Plug Wiring - Electrical - Contractor Talk
Ballast Plug Wiring
Old 02-20-2018, 07:11 AM   #1
memetic's Avatar
Trade: Architect/General Contractor
Rewards Points: 115
Ballast Plug Wiring
Hi,
This ballast did not come with the socket pre-wired. I need to get from the bulb plug to the bulb socket. How do I determine which plug terminal goes to which socket terminal. (Sorry if I am not getting the terminology correct.)
The plan is to cut the plug off and splice in there with some longer wiring (about 3-4') and attach to the bulb socket.
Thanks for any help.
M
memetic is offline
Old 02-20-2018, 07:14 AM   #2
memetic's Avatar
Rewards Points: 115
Re: Ballast Plug Wiring
Picture of socket, just in case.
memetic is offline
Old 02-20-2018, 09:01 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,874
What the *@*$ is this? That can't be an output device. What kind of power supply is that?
What planet did it come from?
Due to circumstances beyond my control, I am here.
480sparky is online now
Old 02-20-2018, 09:02 AM   #4
memetic's Avatar
Rewards Points: 115
OK, it seems the wires to the two round posts go to the two socket terminals that have the screws. I just don't know where the wire from the flat post goes.
Anyone? Please?
memetic is offline
Old 02-20-2018, 09:04 AM   #5
memetic's Avatar
Rewards Points: 115
I am in Brazil, but that is the typical output on all grow light ballasts I have ever seen. I just never bought one that didn't have the female plug that goes to the bulb socket. I called everywhere -- they don't have the female connectors in Brazil apparently.
memetic is offline
Old 02-20-2018, 09:14 AM   #6
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,096
I never thought I would live long enough to see this statement
cwatbay is offline
The Following 3 Users Say Thank You to cwatbay For This Useful Post:
SmallTownGuy (02-20-2018), tgeb (02-20-2018), TxElectrician (02-20-2018)
Old 02-20-2018, 01:55 PM   #7
480sparky's Avatar
I hope the output is a very very very low voltage with a very very very low amperage capability.
Old 02-20-2018, 03:25 PM   #8
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 92
That ceramic socket appears to only have two inputs, one each for the screw terminals. The other two machine screws hold the socket together, and the other two holes are probably just a manufacturing leftover. In other words, two wires go to the ceramic socket, a hot and a neutral, not a ground.
That power "supply" almost looks like a "power conditioner".
P42003 is offline
Old 02-20-2018, 04:09 PM   #9
Business Owner
P42003's Avatar
Rewards Points: 92
I've never dealt with grow light ballasts, but I'm pretty sure that if you're thinking of cutting the female end off that cord to use it as a "supply", you're screwing up big time.
P42003 is offline
Old 02-20-2018, 04:17 PM   #10
480sparky's Avatar
I don't see a female end on a cord.
Old 02-20-2018, 04:39 PM   #11
memetic's Avatar
Rewards Points: 115
I think I posted in the wrong forum.
memetic is offline
Old 02-20-2018, 07:36 PM   #12
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 1,740
Hi,
M
Took me a minute to figure this out.
No, had not seen the specialized female plug like you would want to mate to the male plug in foreground.
The device to receptacle connector way in the background is typical, and I think THAT is what people were expecting.
Only quick way is to plug it in and read it with a DVM.
SmallTownGuy is online now
Old 02-20-2018, 08:19 PM   #13
Business Owner
P42003's Avatar
Rewards Points: 92
"I don't see a female end on a cord"
Yes, I'm losing it. I can't edit or delete my posts either.
P42003 is offline
Old 02-20-2018, 08:37 PM   #14
Business Owner
P42003's Avatar
Rewards Points: 92
BAASP plug:
P42003 is offline
Old 02-20-2018, 09:02 PM   #15
Business Owner
P42003's Avatar
Rewards Points: 92
https://growershouse.com/female-rece...or-lamp-cord-6
P42003 is offline
Old 02-21-2018, 08:37 AM   #16
memetic's Avatar
Rewards Points: 115
This is what I need. Unfortunately, they do not sell those here in Brazil (where I live). I need to chop the male adapter off and hardwire into it. I never had to test lines before with a meter. First time for everything I guess.
memetic is offline
The Following User Says Thank You to memetic For This Useful Post:
SmallTownGuy (02-21-2018)
Old 02-21-2018, 10:35 AM   #17
John the Builder
Did you remove the cover on the off-chance there was a schematic inside?
Old 02-21-2018, 11:29 PM   #18
ComRemodel's Avatar
Trade: electrical
Rewards Points: 164
If you check continuity from the ground prong on the line cord to the prongs on that plug you should be able to see which is the ground. The other two go to the terminals on the socket, doesn't matter which is which. So all you have to do is identify the ground and you know the other two go to the lamp socket.
If you cut the plug off it looks like there will be a green ground and a black & white. Black and white goes to the socket. Green ground goes to whatever fixture you have holding that socket.
-Hal
ComRemodel is offline
The Following User Says Thank You to ComRemodel For This Useful Post:
memetic (02-27-2018)
Old 02-21-2018, 11:39 PM   #19
Business Owner
P42003's Avatar
Rewards Points: 92
The thing that concerns me is that "supposedly" the "output" is to a male end, rather than a safer female socket. That's why I wonder if he doesn't have this thing all jacked up. Hopefully we'll get to find out if there's smoke or not, and I don't mean the type he's growing.
P42003 is offline
The Following User Says Thank You to P42003 For This Useful Post:
SmallTownGuy (02-22-2018)
Old 02-22-2018, 09:49 AM   #20
480sparky's Avatar
This is why electricians don't help DIYers. Let them chlorinate the gene pool by themselves.
Wiring up furniture lights with a ballast HomeSouthern Electrical 1 09-20-2017 05:14 PM
How to properly hook a generator up to a plug to run sump pump reweb Electrical 4 01-19-2017 11:50 PM
Fluorescent ballast wiring rservices Electrical 3 01-10-2016 08:19 AM
Todays wiring rotarex Electrical 11 06-15-2013 03:41 PM
Explanation for wiring? CarpenterSFO Electrical 42 04-05-2013 10:50 AM
