Bad 4" Can Thermocouples??
Old 11-15-2009, 02:19 PM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
I recently just got a slew of calls from 4" cans (IC rated) we put in 2-4 yrs ago with thermocouples built in. Not sure what it is but they are nothing but trouble from what I"ve seen. They either trap too much heat, the thermocouples are crap and just going bad?? Has there been a recall on 4" cans anyone knows about or is anyone else having more than normal calls about blinking cans installed from a while back?? For now I"m going to go and try to excavate any excessive insulation above them and put some socket extenders in and see if that works first.
Bubbles is offline
Old 11-15-2009, 02:22 PM   #2
And I do electrical, too!
480sparky's Avatar
Re: Bad 4" Can Thermocouples??
Check the lamp & trim combo. Many cans have a wattage limit for one type of trim, and a difference wattage limit for another type of trim.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 11-15-2009, 02:44 PM   #3
Master Electrician
Bubbles's Avatar
Trade: Electrical
We ruled that out. They are all trims made for that can. I was on phone with tech guy a bunch last year talking about the can/trim combination. Only 1 light currently is kicking out of 6. It's actually under the wattage rating as well. I could just go and take it out and replace, but I'd rather get to the cause of it since it has been happening way over normal compared to 6" can w/thermo and even the 3" cans are not having these problems either.
Bubbles is offline
Old 11-15-2009, 04:39 PM   #4
Inner10's Avatar
Trade: Control Systems
Time for a dimmer.
Inner10 is online now
Old 11-15-2009, 06:47 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Nothing I've heard or seen, out of at least a couple of hundred over the last few years. Though I have to admit, I find the 4" cans to be a PITA, and try to steer people toward the larger sizes when I can.
Tinstaafl is offline
Old 11-15-2009, 06:55 PM   #6
480sparky's Avatar
Being they, like everything else, are mass-produced, you may simply have the 'Friday 4:55' model.
Hickory 4", 6", 8" pattern Bentz34 Flooring 21 06-28-2010 04:16 PM
3" or 4" ? Celtic Plumbing 75 10-16-2009 09:07 PM
Extending 4" studs to 5 1/2" Danno6102 Carpentry 18 05-29-2009 07:38 PM
Is this in Your area yet??? 4" sharkbites ???? Driftwood Plumbing 11 09-25-2008 06:59 PM
Tapping into a 4" PVC Drain Michael S Plumbing 3 08-11-2008 11:45 PM
