Anyone Know What IRC Electrical Code Was In Effect For Kentucky In 2002-2003?
Need to know what the rules were for buried electrical wire back in Dec 2002-Jan 2003. Anyone know where to find them?
Specifically, what was the minimum depth to bury a cable (10-3 w/g UF-B) in a residential application (not under a driveway)?
Scott (the ex-grunt-tanker-jarhead guy) Last edited by Panzer5; 09-14-2009 at 03:42 PM. |
Fentoozler
Re: Anyone Know What IRC Electrical Code Was In Effect For Kentucky In 2002-2003?
T300.5 hasn't changed since at least 1999 [the last year I have an NEC on computer for].
Why are you looking for IRC codes?
Perhaps I'm thinking of the wrong code (which may be why I couldn't find anything by googling...).
I just presumed because the work was for a residential application, that the IRC was proper. If this ( link ) is the correct code... Does my application fall under Column 1, 3 or 4? (I presume I read accross from "All locations not specified below")
Scott (the ex-grunt-tanker-jarhead guy) Last edited by Panzer5; 09-14-2009 at 04:53 PM. |
Trade: Electrical
If rated 120volts or less and GFCI protected, 12"
otherwise 24" |
#5 | |
Fentoozler
Re: Anyone Know What IRC Electrical Code Was In Effect For Kentucky In 2002-2003?Quote:
Isn't there a 20A requirement also?
#6 | |
Fentoozler
I don't know what the heck that means ???? The NEC comes out every 3 years , ie, '99, '02, '05, '08 ~ ,,,ummm, no '07. You're also in Ky ??? Do yourself a favor and VIEW the NEC here: NFPA 70: National Electrical CodeŽ While having the NEC readily available [whether on the computer, internet or hard copy]...one little item may be missing ~ the amended version that the State/jurisdiction has adopted. I'm curious as to what the investigation is all about
Trade: Electrical
Re: Anyone Know What IRC Electrical Code Was In Effect For Kentucky In 2002-2003? |
#8 | |
I don't want to have to dig up the cable. So if 18" is sufficient, I'm good. If 24" is required... I won't be happy.
Scott (the ex-grunt-tanker-jarhead guy) |
| Security wire code?? | Jason Whipple | Low Voltage | 24 | 03-19-2009 09:02 PM |
| New Code Coming | dayspring | Business | 33 | 10-04-2008 06:08 PM |
| Electrical code question | Kevin75 | Electrical | 2 | 11-23-2007 04:34 PM |
