Anybody Know Anything About Series Circuits?
Old 09-07-2009, 11:57 PM   #21
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
Re: Anybody Know Anything About Series Circuits?
edit.......
Static Design is offline
Old 09-08-2009, 12:00 AM   #22
LRG WoodCrafting
Leo G's Avatar
Originally Posted by Full Spool View Post
You need another given variable for the sequence resulting in 1. Only thing that is giving is 2a since it stays the same in a series circuit, no other variable can be found unless another given is listed. You can't find r1, e1, or p1 with just 2a.
Yes
Because you know eq 2 and 3 and part of eq total you can figure out the missing information easily. Without the other info you would be lost because you really need 2 parts of the equation to get the third part.
It would be a lot easier if this was written out as a schematic. I hate word problems.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 09-08-2009, 12:01 AM   #23
And I do electrical, too!
480sparky's Avatar
Easiest way to do Ohms Law question:
Create a grid, or spreadsheet, with a line for each load and columns for each variable.
Put in the numbers you already know, then you can easily apply The Wheel formulas to calculate the rest.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
HusqyPro (09-08-2009)
Old 09-08-2009, 12:01 AM   #24
#1 stunner
Trade: Design/Build
Originally Posted by Leo G View Post
Because you know eq 2 and 3 and part of eq total you can figure out the missing infor mation easily. Without the other info you would be lost because you really need 2 parts of the equation to get the third part.
check the times on the ninja edit...... I remembered after I hit submit! haha
Will do autocad/ 3d work for food.
SD on facebook... click here
Old 09-08-2009, 12:02 AM   #25
LRG WoodCrafting
Leo G's Avatar
I laughed my ass off, I got it saved in a quote. I hate when that happens to me.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 09-08-2009, 12:08 AM   #26
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Do electricians actually use these formulae on job sites or is this more of a rite of passage thing?
Bob's Lawn & Landscape
When You Want The Best
Serving the LC Valley & Moscow-Pullman
HusqyPro is offline
Old 09-08-2009, 12:16 AM   #27
#1 stunner
Trade: Design/Build
If you don't know how electrons flow or how they react under certain conditions then how will you have any practical field knowledge?
Depending on your line of electrical work will determine if you will be calculating basic formulas, do I ever do calcs on finding Rt on a residential application ? No I do not, but when I am modifying honda computers for turbocharging and n20 applications then yes.
Old 09-08-2009, 12:19 AM   #28
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
I was just curious. Just because I haven't seen an electrician break out a calculator on a job doesn't mean that some don't.
What would be some jobsite examples of how/when I would use this information?
Give me something I can relate it too and perhaps I can understand it better.
HusqyPro is offline
Old 09-08-2009, 12:30 AM   #29
solar guy
naptown CR's Avatar
Trade: solar contracting
your instructor is baiting you looking for a happy ending. Although OHM's law is useful to know almost nothing is dove in series any more.
naptown CR is offline
Old 09-08-2009, 12:32 AM   #30
Kgmz's Avatar
Example: Some wall heaters in a residence.
Do I want 120 or 240 volt heaters and what size wire and circuit do I need.
Two(2) 1500 heaters
1500 watts / 120 volts = 12.5 amps, 2 of them will draw 25 amps so pushing it with 10 gauge wire on a 30 amp circuit.
1500 watts / 240 volts = 6.25 amps, 2 will draw 13 amps so would be better of this way with 12 gauge wire on a 20 amp circuit.
Kgmz is offline
The Following User Says Thank You to Kgmz For This Useful Post:
Old 09-08-2009, 12:34 AM   #31
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Series is where everyting is hooked together. Unplug one component and nothing works.
Paralell is where everything feeds off a common source. Unplug one component and all the other stuff still works.
That sound about right?
HusqyPro is offline
Old 09-08-2009, 12:35 AM   #32
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Two(2) 1500 heaters
Excellent example. Thank you sir.
HusqyPro is offline
Old 09-08-2009, 12:39 AM   #33
#1 stunner
Trade: Design/Build
Two(2) 1500 heaters
Depending on wire type and how much room you have in the breaker box.
Right, just picture the old type Christmas lights and you will be fine. Here in a couple of weeks you will be doing parallel and series circuits together which are blast, well depending on your level of education you're pressuring.
Old 09-08-2009, 12:42 AM   #34
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
I'm pursuing a Bachelors of Applied Science in HVAC and Appliance Technology.
With recent health problems I may scale that back to an Associates of Applied Science in HVAC and Appliance Technology.
HusqyPro is offline
Old 09-08-2009, 12:54 AM   #35
Inner10's Avatar
Trade: Control Systems
I know I do, quite handy for some quick trig on funky bends too.
Onece you practice ohm's law enough (google it for practice problems) and understand it you will look back and feel really stupid...yet at first I could see it being rather daunting.
Inner10 is online now
Old 09-08-2009, 01:02 AM   #36
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Right now we're also learning about forced air heat. Gas, electric, and oil fired furnaces. Next semester I believe is air conditioning. After that we get into refrigeration and appliances. Which I'm personally very excited about. I'm looking hard at buying into a Mr. Appliance franchise. I'd also like to own a Aire Serve as well. I know the guy that bought Mr. Rooter is dominating the market down here right now. The guy that bought Aire Serve in Spokane supposedly put six big HVAC cntractors under his first year in business.
I see good things if I do well in this course and get my degree.
HusqyPro is offline
Old 09-08-2009, 07:40 AM   #37
LRG WoodCrafting
Leo G's Avatar
Wait until you get into fluid dynamics of air flow calculations. This will look like childs play.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 09-08-2009, 06:51 PM   #38
LRG WoodCrafting
Leo G's Avatar
So how'd you make out on yer homework? You getter done?
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 09-08-2009, 06:54 PM   #39
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Yes I did. Missed a few. 92% was the grade I got.
If we get into that fluid dynamics stuff you may have to hold me.
HusqyPro is offline
Old 09-08-2009, 07:33 PM   #40
LRG WoodCrafting
Leo G's Avatar
Don't come looking for me. I don't know squat about it. I'm sure I can figure out the formula's, but I know I won't want to.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 25 12-24-2009 01:10 PM
World Series 2009? Safety Guy Off Topic (Non Trade) 40 11-08-2009 07:39 AM
Pella Designer Series Competitors??? TurnkeyConst Windows, Siding and Doors 2 07-22-2009 12:07 AM
Security wire code?? Jason Whipple Low Voltage 24 03-19-2009 09:02 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
