Amping Up
Hello and thanks ahead of time.
In reference to a 20 amp circuit, does this mean the sum amperage of all appliances connected should not excede 20 amps, or that no one item shall excede 20 amps. (almost the same thing)
Repair/Remodeling Tech.
Trade: Repair and Remodeling Services
Re: Amping Up
It means the sum of all outlets **appliances or devices used at the same time** (which does not mean ONLY receptacles) on the circuit.
**Edited for our beloved union electricians so that they may understand.
Jim P. Last edited by jproffer; 03-24-2007 at 08:05 PM. |
Electrical Contractor
Trade: Electrical
Re: Amping Up
This question cannot be answered as asked. It is way to vague.
Of course the amperage of applainces can be more than 20 amps. You just can't use them all at the same time. Unless of course they are hard wired. Or there is a mix of hard wired and receptacles. Then there is stuff like electric heat, which is limited to 80%. Same goes for a water heater, and anything else considered a continuous load. For receptacle circuits you can have 978 amps worth of things plugged in if you want.
Trade: Renovations
Re: Amping Up
Dammit, I'll have to redesign, I was counting on 979.
Union Electrician
Trade: Inside Wireman
Re: Amping Up
So suppose I have three 'outlets' in my bedroom on a 15 amp circuit......Now suppose I have 3 vacuums in my household and like to use them all in in one bedroom at a time?
Now, by someones logic..........(#2) I need every circuit dedicated??? But I don't see this as true. Number of circuits is based on sqaure footage, though I'll point out that the NEC requires too few circuits based on square footage. Last edited by Sparky Joe; 03-23-2007 at 03:16 AM. Reason: changed the word receptacle to 'outlet' seeing as someone thinks an outlet is not a receptacle |
Re: Amping Up
Receptacle = "the thingy that the toaster plugs into"
Outlet = Lights, Receptacles, Stove, Oven, Dryer...or any other way that electricity is LET...OUT. I'm surprised you didn't catch that Joe, being a union electrician and all. Hang on I'll edit the other post just for you Joe.
Jim P. |
Trade: Electric
Re: Amping Up
Yeah that is funny... Also, correct me if I'm wrong but I believe square footage is only used to come up with a number of circuits to base service size calcultions off of. You always end up with more circuits than your 3w(resi) per sq ft lighting and small appliance circuits and everything else says you need. Recepts you count as 180va load, and you get 1800va to a 15a circuit, so 10 recepts per 15a circuit, 13 for a 20a circuit etc..
you can't put an appliance with a nameplate amperage rating higher than the ampacity of the circuit... you can have a dozen 20a appliances on a 20a circuit, as long as they are cord and plug connected. If they are hardwired it dependsd on what they are and how many, and there are demand factors that apply. So in many cases yes, the sum amperage of all apliances will exceed the amperage of the circuit, but one appliance alone can not. Last edited by Liquid Force; 03-23-2007 at 05:29 PM. |
#8 | |
Trade: Licenced Electrician
Re: Amping UpQuote:
Non-union electrician= plumber or drywaller doing electrical work Only joking.....please don't anyone take it seriously |
Trade: Electrical
Re: Amping Up
How can we take you seriously with an avatar like that?
Union Electrician
Re: Amping Up
I like it Eddy
And i address that JP in the reason for my edit, just didn't want to confuse the original poster to think there is a difference. Thanks for the definition btw, I know that helped many people that didn't what the word 'outlet' means as related to electrical |
Service & Repairs
Trade: Electrician
Re: Amping Up
I'm sure there are plenty of non-union electricians that know the difference between an electrical outlet and an electrical receptacle.
Union Electrician
Re: Amping Up
But do they know a receptacle is an outlet?
In other words, every box you install is an outlet. |
Trade: Electrical
Re: Amping Up
Ummm, Joe, a switch is NOT an outlet. It is a control.
So not every box is an outlet. Man, this thread is going places.
Re: Amping Up
I'll edit the first one....again
Jim P. |
#15 | |
Re: Amping UpQuote:
In that sense, I can see it as an outlet in a series of outlets. Never thought about it. Just a bored painter here that does his own elctrical. |
Trade: Electrical Contractor
Re: Amping Up
The 180va load is not counted in resi. work.
We are the people (our parents warned us about) (Jimmy Buffett) |
Thom
Re: Amping Up
There may be local amendments. Check with your state, county, city first.
My state amended the rules to max at 10 outlets (lights or plugs) on a circuit (residential). It doesn't matter if the circuit is 15A or 20A, 10 outlets. |
#18 |
Union Electrician
Re: Amping Up
"Outlet-A point on the wiring system at which current is taken to supply utilization equipment"
I agree Pete, but 'a point at which current is taken' raises a question. Is the transformer then the only outlet? I've always considered an outlet as an accessible place to tap off the power system such as a box. |
#19 |
Trade: Electrical
Re: Amping Up
This is a discussion that can go on for days, but I'll reply.
What if that box only contained a switch loop? You could not then take power. See the point. I know this has been debated at great length. Maybe I'll dig up an old post.
